Anonymous User
Re: Two stepper z-axis January 21, 2016 05:54AM |
AudaciousTuddle
Ah. Now I see. I haven't thought about avoiding microstepping in layer heights, but I'm going to start doing that. Right now I have a 1.25mm lead so staying in multiples of .00625. Or .004mm once I get my leadscrews installed with the .8mm lead.
Re: Two stepper z-axis January 21, 2016 07:18AM |
Re: Two stepper z-axis January 21, 2016 02:10PM |
WZ9V
Do people find they have problems with the two z-motors going out of sync and causing leveling issues?
Re: Two stepper z-axis January 21, 2016 02:17PM |
Re: Two stepper z-axis January 21, 2016 02:20PM |
Re: Two stepper z-axis January 21, 2016 03:17PM |
Re: Two stepper z-axis January 21, 2016 04:09PM |
Anonymous User
Re: Two stepper z-axis January 22, 2016 05:17AM |
5mm diam is too small. 8mm is the minimum usable. Standard M5 threaded rod pitch is 0.8mm, never heard of 1.25mm wich would be too coarse.Quote
AudaciousTuddle
I found a T5 x .8mm leadscrew. It's in the mail now. Currently I am using m5x1.25 threaded rods but they are pretty bent, which is why I am going to the leadscrews.
Re: Two stepper z-axis January 22, 2016 07:59AM |
MKSA
Where did you get TR5 with a 0.8 mm pitch ?. 1mm is the standard.
Anonymous User
Re: Two stepper z-axis January 22, 2016 03:41PM |
AudaciousTuddle
MKSA
I found these ones at [www.ebay.com].
I also totally screwed up some numbers. The ones I'm using now are M6x1.00. I got mixed up with another project that used M8x1.25. And if you do some wikipeading M5x0.8 or 0.5 is standard. Hopefully this guy isn't marketing threaded rods as acme screws, but the picture looks like it has the trapezoidal threads at least.
