Re: Chinese eBay 3D printer - Story so far, and request for advice March 24, 2016 03:27AM |
artur_k
brs1701d
Hi artur k,
No expert myself, still learning, but I’ll try and give you some pointers.
The temperature issue is likely due to the wrong thermistors being fitted. They should have a resistance of 100kohms, the ones fitted to mine were 50kohms. Once replaced the readings were fine without any changes to firmware. I checked the Marlin config file for the resistors supported and fitted a 100k NTC 3950 sourced from ebay, and an NTC 100k from element14 (part number 135-104LAF-J01).
I had similar experiences with the motors. I was using pronterface to control the printer directly over usb whilst I got used to the functions and found it easier than using the LCD screen. It turned out I was forgetting to ‘home’ all the axis when first connecting, once this was done (one at a time to test the endstop switches), everything behaved itself.
I have found that the printer firmware to be setup adequately for my needs at the moment. I also initially beleived that I needed to update, and I probably will at some point, however I felt learning the basics before I jumped in too deep would be the correct path to take.
I hope these points help you make some progress, hang in there, I found it tough at the beginning also, it is worth persevering.
Thanks, I'll get those thermistors once I start the printer.
I tried homing, the problem is that the motors are not moving at all so cannot hit stops. One driver that is showing signs of life is acting weird as well. I only works in full step, 1/2 and 1/4 and only on low pot setting (full clockwise). In 1/16 it is still trying but unable to move. If I help it by hand then it moves but the distances are waaaaaay off.
I ordered a set of new motor drivers, to see if those were faulty. Contacted the seller as well, I'll see what he says.
In the meantime I tested heating elements and found that both are getting up to the temperature in less then a minute so all is well there.
I also have a question about the endstops. I received 3 endstops in NC configuration connected to XYZ MIN. The board has 6 ports for them. When I send M119 I receive back that XYZ MAX are tripped - is it the same on yours?
Re: Chinese eBay 3D printer - Story so far, and request for advice March 24, 2016 09:03AM |
elwood127
Mrp23
Hi brs1701d,
I ordered this: [www.ebay.co.uk] in LEFT hand and received the one on to the left of the picture so i would say it would be which side the motor is mounted (maybe?).
Please note that part did not fit correctly for me due to the orientation of the block in the the L shaped bracket so i used the springs and screws with this and printed myself out of trouble!
As you can see in my picture i have the motor mounted to the right side.
one thing i noticed after assembly was that when i homed the machine the etruder was off the table by 10mm+ has anyone else found this to be the case?
with this setup now it is perfectly aligned to the corner of the bed .
Having the hotend off of the plate makes for easy extrusion. Over the plate blocks this task.
Re: Chinese eBay 3D printer - Story so far, and request for advice March 24, 2016 09:51AM |
brs1701d
Yes, the XYZ MAX are reported as tripped. Hopefully the replacement drivers will work, have you made a close inspection over the rest of the board to ensure none of the components look fried?
I found the seller to be responsive, however, apart from a small refund, that was as far as it went. With the help of this forum, and additional research, I have had to solve the issues myself
Re: Chinese eBay 3D printer - Story so far, and request for advice March 25, 2016 04:40AM |
artur_k
brs1701d
Ah, so the end stops are ok. I have inspected the board and it looks fine. All drivers are getting signal. When I put the only responsive driver in, I get motors buzzing and moving only with all jumpers removed.
I also checked voltages on the drivers with a multimeter and all is fine there - getting 5 and 12v. Checked the motors as well - all got 2 pairs.
Re: Chinese eBay 3D printer - Story so far, and request for advice March 25, 2016 07:28AM |
Mrp23
Hi ettie1972,
If you are wanting to clarify the positions of all connectors on the gt2560 board take a look here
under interface layout: [www.geeetech.com]
what exactly is the issue with loading the filament?
Re: Chinese eBay 3D printer - Story so far, and request for advice March 25, 2016 04:56PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice March 27, 2016 02:44AM |
Re: Chinese eBay 3D printer - Story so far, and request for advice March 27, 2016 05:30PM |
brs1701d
With my limited experience, I have no other suggestions for you at the moment.
Have you had any response from the seller?
Re: Chinese eBay 3D printer - Story so far, and request for advice March 28, 2016 03:07AM |
artur_k
brs1701d
Yes I had response. He said that he sent a copy of the firmware to my paypal address but I haven't received anything and he also asked for pictures of the board.
I installed 4 new drivers - drv8825 and it is working fine now. I don't know what caused that all 4 drivers were faulty. I put new ones in and they worked straight away.
I also had some bed adhesion issues it was very frustrating. Finally I am just using plain glass without blue tape but I put some pva glue on just before printing. Now I have to work hard to pull the prints off the surface after printing. The print quality is very good for such a cheep printer.
My power supply which I received with the printer is marked as 180W. So 15A. I have no problems with it.
I have just one problem left. My prints are 0,3mm taller then they should be - exactly 1 layer?? It doesn't matter if it's 10 or 20mm.
Anyone knows where to change it in slic3r?
Re: Chinese eBay 3D printer - Story so far, and request for advice March 28, 2016 04:37PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice March 29, 2016 05:01AM |
furbrain
I had a lot of weird problems with mine - but only when running from the SD card. At times it would seem like either the X or Y axis would home themselves before continuing with the print, and sometimes the extruder would reverse all the filament out of it. Since then I have added a raspberry pi as a USB controller running octoprint - and I've had no problems. I wonder if either the 5V regulator was flaky (and gets a fresh 5V supply through the USB port) or if there is a problem with the SD card.
Phil
Re: Chinese eBay 3D printer - Story so far, and request for advice April 01, 2016 03:40AM |
furbrain
Phil
Re: Chinese eBay 3D printer - Story so far, and request for advice April 03, 2016 05:42PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 04, 2016 11:15AM |
arleseydiver
Hi, I've recently just bought one if these as well. I am having similar problems with the thermistors, and rasping on the extruder.
When the item arrived, the rods were bent, and the holes had been cut in the wrong places on the frame.
Does anyone know if it is possible to backup or download the running firmware on the gt2560 board?
Roger
Re: Chinese eBay 3D printer - Story so far, and request for advice April 04, 2016 11:45AM |
arleseydiver
Roger
Re: Chinese eBay 3D printer - Story so far, and request for advice April 08, 2016 09:07AM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 08, 2016 10:49AM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 08, 2016 12:55PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 09:00AM |
ad456m
I plugged them in as indicated in the manual. Ext1 to lcd and ext2 to sd. Might b worth a shot to swap em.
I'm still running stock firmware whatever it may be. I did think about flashing it with Marlin but don't know about configuration so guessed it was best left alone as to not create more problems.
I did hook it up to my Mac and cura but the printer need to onboard setting configured as the extruder comes over the edge of the bed as it is so left that alone too before I break something. It did give me the idea that everything else is fine apart from a clicking extuder. Lowering the feedrate might fix that.
Thanks for the ideas, I'll try them next time I'm home.
EDIT :- Swapped the cables but no joy, they must've been right to start with. here's some pics i took before the swap
I'm suspecting a shot lcd, I'll order another from somewhere to try out. Incase I've screwed up the config, does anyone have any settings for this thing? Or a firmware and settings to flash it with?(I'm competant with arduino but no master, lol)
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 11:37AM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 01:21PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 01:34PM |
ad456m
WOOOOHOO! I have life, that Printrun is exactly what i was after
The calibration of the printer is a wee bit off but all the bits respond properly and I've got a clunking extruder but not worried about that, i'm sure I'll figure that out.
I was planning to replace/upgrade to drv8825 all round in (a short) time too, nice to know i can and i have those thermistors in the mail.
I'll have to read up on leadscrews as mine are slightly bent but don't care too much yet as theres plenty to learn.
Thanks ever so much folks, you've totally sorted my optimism out as i was starting to think i'd knackered the thing, lol.
I'll start looking through the fixes for the extruder now and find a nice wee cube to amaze myself with
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 02:07PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 02:30PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 09, 2016 03:02PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 23, 2016 04:04PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice April 23, 2016 11:54PM |
Lucas Azevedo
Hy everybody... Soo i bought the exact same 3d printer and i can't calibrate the z axis ... i encounter 2 problems
1º doing the auto home the extruder get out of the bed
2º the extruder is crashing in the bed ...
Anyone facing the same problem ?
Re: Chinese eBay 3D printer - Story so far, and request for advice April 26, 2016 11:25PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice May 01, 2016 09:52PM |
Re: Chinese eBay 3D printer - Story so far, and request for advice May 03, 2016 03:53AM |
shifta
Hi all first post here, i have just got this printer but the instructions i was sent aren't great has anyone got an English copy.
Btw thanks for all the info on this thread can watch out for the issue that might come up.
