RepRap Guru i3 Printer Kit (Official Thread) April 30, 2016 01:49PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 03, 2016 10:58PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 03, 2016 11:15PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 04, 2016 10:55AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 18, 2016 12:12AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) June 02, 2016 04:13PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) June 07, 2016 01:55PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) June 08, 2016 09:14AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) June 08, 2016 10:15PM |
But I can't figure out which way round to make it work. For now I've just moved it to the left side.Quote
Tip: You can flip the end stop over and and attach it on the other side of the end stop holder and put it under the hot plate to avoid potential
clashing of the leveling knob.
Re: RepRap Guru i3 Printer Kit (Official Thread) June 09, 2016 09:11AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) June 09, 2016 09:12AM |
deadpool66
Hey guys going to upgrade to an e3d v6 what changes need to made to the firmware?
Re: RepRap Guru i3 Printer Kit (Official Thread) June 11, 2016 11:48PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) June 12, 2016 08:39AM |
ayryq
A couple other comments for this thread:
1. I found that the X-axis smooth rods were too long, or the holes for them too shallow, to get the entire assembly to fit together square (Z threaded rods had to bow out). I cut off about 3/8" from each rod and now it works great.
2. One of the soldered leads on the back of the RAMPS board (for the 12V plug) stabs the power connector on the arduino mega. I had to clip it closer to the board to make it fit.
Re: RepRap Guru i3 Printer Kit (Official Thread) June 12, 2016 08:41AM |
goaltend357
HELP!!!!!
My machine keeps crashing into the endstops and tries to continue movement. It is possible I missed something, but I believe I set everything up correctly in the configuration. This is my first electrionics project.
Re: RepRap Guru i3 Printer Kit (Official Thread) June 15, 2016 02:46PM |
[email protected]
Ok, I just bought the RepRapDiscount Full Graphic Smart Controller. I have added
The U8glib library and added the following line to Configuration.h
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER.
Still not working. Any ideas?
Re: RepRap Guru i3 Printer Kit (Official Thread) June 15, 2016 02:50PM |
ayryq
[email protected]
I have an idea. The copy of Marlin supplied by RepRapGuru is so old it does not support this LCD controller (even though RepRapGuru now sells the controller through their website). I bet if you got a current build of Marlin, then went through line-by-line to set it up the same as the REPRAP_GURU_MARLIN version, that it would work. I think just adding the line won't do it - you have to have a version of Marlin that already has the line, so you can uncomment it.
Re: RepRap Guru i3 Printer Kit (Official Thread) June 20, 2016 09:45AM |
ayryq
goaltend357
HELP!!!!!
Probably your stepper motors are plugged in backwards. Or, less likely, you have repetier-host set to "MAX" instead of "MIN" in table dimensions so it's looking for the end-stop on the wrong side.
Re: RepRap Guru i3 Printer Kit (Official Thread) July 19, 2016 12:47PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) July 25, 2016 04:17PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 14, 2016 03:29PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 19, 2016 08:45AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 19, 2016 08:46AM |
deadpool66
Hi guys,
Been having some anomalies with my printer the last few days reprap guru . It all started when I added a second fan and wired the e3d fan directly to the psu. I powered the fan down and I'm still having problems.
Now I'm having issue hitting target temp and now today I keep have sd card reading problems on my discount lcd.
Where should I start?
Re: RepRap Guru i3 Printer Kit (Official Thread) August 19, 2016 09:51AM |
I had the same problem. I solved it by cutting down the rods - probably better than drilling out the plastic parts. As shipped they were definitely too long, and I spent longer than I should have attempting to force the frame together before getting out the angle grinder.Quote
radwizard
The X-Axis Housing didn't allow for the chrome bars to fit all the way in. This originally caused the entire frame to bend and bow. I called REPRAPGURU and the individual told me to drill out the holes. I have done this, but it seems to still have issues. I did however get the chrome bars to slip in slightly better, but there is still and issue.
Me too. RRG quickly shipped me a few extra bearings, but I have to say I don't think there's too much wrong if a few of the tiny balls fall out. I think the problem is caused by twisting the rod in the bearing. The bearing is designed for ONLY linear motion.Quote
radwizard
Additionally all of this stress on the unit has caused the Z-Axis bearings to brake and the ball bearings have come out. I have used a magnet to collect the super tiny bearing parts up.
I bought some ferrules that definitely helped with the terminal hookups. Would recommend looking for "bootlace ferrules" for a lot of these connections. I've found a lot of other uses for them too, so it wasn't a complete waste of money. There are "things" on thingiverse, for various printers, that act as a strain relief for the heatbed wires. The constant motion in the Y axis causes that connection to fail. It might be possible to adapt one of them to the RRG kit. See here or here for exampleQuote
radwizard
1.) I fixed the heatbed. I pulled out the wires from the Adrino restriped the wires, then reconnected. I also soldered the wire better to the heat plate. So I'm considering that issue resolved. Still need to figure out the rest. I will post more if I get further resolution here.
Me too. For future reference, the "big" side of a polarized USA outlet is the negative, the smaller hole is the positive. The included cord is not polarized but you can see which prong goes where. BUT... the included cord is way undersized for the application. When using the heatbed my power cord got HOT. Throw it away, don't have a house fire, and buy a thicker cord from a hardware store. Included cord was smaller than 20AWG, I replaced with 16AWG.Quote
radwizard
2.) For the plug that went into the power supply and the wrong color coding on the wires. What I did to resolve is that I checked the conductivity using a multimeter on each prong to find the correct wire. I also looked up a schematice of a stand USA power socket. This allowed me to deduce which wire went to where. My colors on my wiring was Dark Blue, Red, and Light Blue.
Re: RepRap Guru i3 Printer Kit (Official Thread) August 19, 2016 11:37AM |
I don't have a grinder. That would be an investment. What did you cut your lengths to?Quote
ayryq
I had 1 extra pair. My thermastor on the hot end was broken. They shipped a replacement out. I appreciated that.Quote
ayrq
ayrq
ayrq
You may be interested to read my review at amazon. I gave it four stars. I would definitely be frustrated with the motor problems you mentioned; I didn't have any of those. Did you adjust the stepper trim properly?
Re: RepRap Guru i3 Printer Kit (Official Thread) August 19, 2016 11:47AM |
radwizard
Re: RepRap Guru i3 Printer Kit (Official Thread) September 09, 2016 05:31PM |
radwizard
Hello,
I purchased a reprapguru via amazon. Having lots of issue with this thing. Heatbed looks to be broken, it wont power up anymore, it did at one point. One of the step motors on the Z-Axis doesn't work constantly and seems to move backwards and forwards randomly and stalls randomly. The nuts that fit into the Xaxis housings often back out of the housing. The X-Axis Housing didn't allow for the chrome bars to fit all the way in. This originally caused the entire frame to bend and bow. I called REPRAPGURU and the individual told me to drill out the holes. I have done this, but it seems to still have issues. I did however get the chrome bars to slip in slightly better, but there is still and issue. Additionally all of this stress on the unit has caused the Z-Axis bearings to brake and the ball bearings have come out. I have used a magnet to collect the super tiny bearing parts up. The thermostat was broken on arrival, this was replaced. Also the power plug that came with it didn't match the American standard of color coding. Also the black corners on the frame that hold the y-axis base are not clean, and this causes issues with trying to level the heat bed. This REPRAPGURU is crap. I'm about to ask for my money back. I'm hoping I can get some help with this before I request my money back and go with a different company. I know there is a level of understanding and craftmenship that is needed to assemble these units, but the parts are junk to start with. Really need some help solving this issues. I was hoping to get this thing in some working order so I could at least print up upgrade and replacement parts. Although this is not possible with the printer in its current none working order. Specially with how the Z-Axis motor is behaving. I can post pictures and videos if needed. I'm willing to work with the company I purchased this from.
Update
3.) Wasn't listed here, but for others having issues with the LCD, I had to turn the Contrast Screw on the back to see the LCD. I didn't know about that when I set it up. It wasn't in the directions. So if anybody else is having issues with the RepRapGuru LCD screen adjustment. That is what I did. This wasn't broken, just couldn't find any resources for this, I just sort of figured it out watching this youtube video [www.youtube.com]
4.) Video of what I suspect to be a broken step motor out of the box. [www.youtube.com]
5.) Extra Bearings where provided. I was pleased to have the back ups. I swapped them out along the Z-Axis. RepRapGuru gives extra parts. So a big plus there.
Update 8/19/2016 8pm PST
6.) Well, I spoke to somebody over at RRG, super nice guy, helped me to check the coils on my motor. Looked to be okay. We discussed some other options. I made adjustment, they where mechanical adjustments. I started to print a 20mm cube to see who it would go. It was going okay. And then the system turned off. It took me a few minutes to figure out what happened. Looks like a melt down. See burn_out picture. Back to step 1.
Update 8/20/2016 3pm PST
6.a)Ordering replacement Adrino. Thank you to "Ayryq" recommendation of using ferrules. I will absolutely being using these everywhere I can. See Burn_Out Picture and why it is a great idea. I'm going to have to wait for the new parts to come in to move forward. I'm really hoping that the Motors, Controllers, LCD and other electronic parts are okay. This was a hard less to learn. Well worth learning the less, will cost me the price of a nice meal at a store. Adrino is like $10. Hopefully that is the extent of money I need to spent on replacement parts.
6.b)Also installed Flange Bearings. They came with the kit. I wasn't aware of what these where until I spoke to RRG. The construction manual doesn't show these in the pictures. It only mentions that they are not included in with their kit. I'm hoping this will resolve the issue I'm having with the Motor shown in the youtube video.
Re: RepRap Guru i3 Printer Kit (Official Thread) September 09, 2016 05:50PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 05, 2016 06:57PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 11, 2016 06:18PM |
