New to building a printer, and bought the Folger 2020 Prusa i3 kit.
At the stage where I'm trying to move the axes in Repetier, however no command, homing nor manual control works for any axis. I am getting temperature readings. Endstops light up when triggered.
Things I have tried:
I have used M119 to check the endstops and all are open, and say triggered when pressed down. (I'm using the most recent version of Marlin).
Power supply seem to be ok, fan is working and bed heats when turned on.
Switched endstop in 7th pins to 6th pins.
Inverting any motor wires does nothing.
Turning the turnpots results in squealing, grinding noise, and heating up of the motor (focusing on x axis right now).
Any suggestions?
