calibration issues September 22, 2016 12:02PM |
Re: calibration issues September 22, 2016 01:15PM |
You probably have 16 teeth pulley, which gives 200 steps for 1/32Quote
siddharta
Hi all having some problems calibrating an Anet A8 with RAMPS 1.4 electronics and Repetier 0.92 firmware. Mounted on the RAMPS board are 4x DRV8825 with Vref adjusted to half of the stepper current (0.9A). The steppers are 1.8deg 0,34 Nm models, from a manufacturer named "High Efficiency Motors".
1) I have all jumpers in place under the stepper drivers, which I understand would yield 1/32 microstepping for the DRV8825 drivers (I've some A4988 waiting to arrive and those I had on hand). I used RepRap calculator to get the no of steps/mm. Assuming 8 teeth pulleys (didn't count before mount the GT2 belt), GT2 belt and 1/32 microstepping that would yield 400 steps/mm.
Nevertheless the most accurate result so far is with a setting of 200 steps/mm, so it would seem it is operating on 1/16 microsteps.
For example, using Repetier Host
- move the Y axis 100 mm yields 99 mm of actual movement
- move the X axis 100 mm yields 100,5 mm of actual movement
(are those measurements acceptable? I'm not sure if they are measuring errors or expected deviations).
Threaded rod or a Trapezoid rod?Quote
2) The Z-axis I just can't seem to get right. Again using RepRap calculator, for M8 threaded rod and 1/16 microstepping gives 2560 steps/mm and 5120 for 1/32.
However, for 100 mm of movement I get an actual movement of 65,1 mm using 5120 steps/mm and 32,2 mm using 2560 steps/mm.
Why would that be so off?
Extruder might be skipping steps or slipping.Quote
3) Lastly, extruder calibration seems very weird. I'm using the what I understand to be normal method - feeding filament into the extruder, marking at 120mm or so, feeding 100 mm through the extruder using Repetier Host and measuring. The issue here is that I'm getting wildly inconsistent results, for a given steps/mm the actual filament movement can vary as much as 20mm.
Any insights are appreciated!
Regards,
Re: calibration issues September 23, 2016 03:52AM |
Re: calibration issues September 23, 2016 11:07AM |
Re: calibration issues September 24, 2016 12:15PM |
Re: calibration issues September 25, 2016 10:34AM |
Veesta
MK8 should work. I have one too.
PLA is bitch.
When you print PLA, you need to keep it flowing constantly. Otherwise it will melt and expand in the nozzle and jam it.
I had a practice to pull out PLA filament every time print ended and use a 1,5mm brass wire (flat end) to push all that melted filament out from the nozzle.
i had to, because it was not possible to start print again after nozzle cooled down. So i did this after every print.
This way hotend/nozzle was good to go for the next print after it cooled down.
Now i use few drops of Dexos2 in the barrel and i can leave the filament as is.
Have not had jams since.
DaGameFace
would recommend using 1/16 microstepping max. for kicks, try that and see how it works for x and y
Re: calibration issues October 03, 2016 06:40AM |
Re: calibration issues October 03, 2016 08:24AM |
Re: calibration issues October 03, 2016 05:55PM |
Re: calibration issues October 05, 2016 03:30PM |
Re: calibration issues October 06, 2016 01:23AM |
Re: calibration issues October 06, 2016 08:51PM |
Re: calibration issues October 27, 2016 07:17PM |
Veesta
I think you should just start adding more steps to the calibrated values to get it more accurate.
Forget the calibration procedure. Add more steps to your current values, print and measure.
Say, +1-2% to the current value. Print and measure.
When your part is larger than target. Reduce the steps.
