Having a problem here. I've got a new built Tronxy P802M Prusa i3 clone. I've tested the printer to verify it functions. Ran it without filament.
Config: Repetier .91 firmware, Melzi 2.0 board. Trying to print from a gcode file made in Cura.
Everything seems to work fine except it will not extrude. No idea how else to test this (sorry for being such a newb here)
I look in the extruder menu and it says Ext 1 off. I'm assuming that would be the second extruder if this were a dual extruder machine.
Also, the bed and extruder hot end are both getting to normal temps. Dry run is turned off.
Thanks in advance for your help.
Edited 1 time(s). Last edit at 03/03/2017 12:22AM by Twmaster.
TW
