Re: Cura settings
April 13, 2017 07:34AM
Thanks StatorCodex I'll try different baud rates.
Adrian
Re: Cura settings
April 14, 2017 12:00PM
Hi guys
I am getting there. I've got a spare board now and I've got Arduino to talk to it. ( TFFT ) Now when I plug my board to the lcd it lights up but It's blank.
What am I doing wrong. Config H in the attachment.
Thanks
Adrian
open | download - Config H.txt (56.3 KB)
Re: Cura settings
April 14, 2017 11:37PM
Is the Mega being powered by a separate supply, i.e. the computer., even when printing from SDcard.
1) I've noticed the RAMPs will backpower the LCD from the PSU for me, but do nothing (when I thought I didn't need to plug in the USB b/c I had it on SDcard printing).
2) Also, contrast can usually be adjusted by a potentiometer on the backside.
3)
//============================= LCD and SD support ============================
That section will have below it your LCD settings. Read and google, and tell us what you see.
4) What does your LCD have written on it's backside?
Re: Cura settings
April 15, 2017 04:40AM
Hi thanks for the reply.
My problem is I have no clue what LCD I've got I have googled them but theres hundreds of them. I have attached a couple of pics
Adrian
open | download - 17916615_10154525346306033_309650038_o.jpg (178.3 KB)
open | download - 17968119_10154525334696033_883722292_o.jpg (279.4 KB)
Re: Cura settings
April 15, 2017 09:59AM
You have a
#define REPRAP_DISCOUNT_SMART_CONTROLLER
Re: Cura settings
April 15, 2017 11:48AM
Thank you
Re: Cura settings
April 17, 2017 10:55AM
Thank you to all you guys.
I had my first sucsesfull print. It's a Z axis anti wobble part. Im well happy.
Adrian
Re: Cura settings
April 17, 2017 11:51PM
Good job! Feels good, don't it.
Have you already printed a Z axis fine adjustment knob? Maybe your printer came with one, but for the FT Prusai3 2020, it was the most important piece not present in kit or .stl files.
Example: [www.thingiverse.com]
Also, as you figure out answers, you can help others who have problems like yours by editing your OP with the solutions.
Okay. Just realized we can't edit long past posts. Example still holds, just 'Quote' your post where the problem was and replace the 'EDIT' with your reply.
Example: OPOPopopPOpopopoop
opopopopppppppppopop
popopoooopopopopopopo
EDIT: Figured out what the timeout error was.
Fixed it by doing xyzxyzxyz.
EDIT2: Figured out why my LCD didn't light up.
Marlin was stock with 'LCD xyzxyz' uncommented.
So I uncommented ##define REPRAP_DISCOUNT_SMART_CONTROLLER
and it worked.
Edited 1 time(s). Last edit at 04/17/2017 11:53PM by VonRansak.
Re: Cura settings
April 18, 2017 04:35PM
Bee69
Adrian
Picture or it didnt happend!
Re: Cura settings
April 19, 2017 06:17AM
Here's the proof. lol
[i1253.photobucket.com]
Thanks guys.
Adrian
Re: Cura settings
April 19, 2017 10:15PM
One thing that is always good to try after calibrating movement as you have done.
Is to play around with the temperature a bit. Usually on the hotend side +/-5 is a good interval. On the bed, usually a little less drastic interval. But if the filament you are using is has a 30 degree range on it, a bisection search is probably faster. (I use cheapo Microcenter filament, so bisection it is). Every roll can act different. Most colors act different. Troubleshoot one heat source at a time.
Also, if you don't have one already, the purchase of a decent digital micrometer is a worthwhile investment.
Edited 3 time(s). Last edit at 04/19/2017 10:17PM by VonRansak.
Re: Cura settings
April 20, 2017 01:51PM
Thanks for the info i've got a digital micrometer and I play with all I can.lol
Adrian
Edited 1 time(s). Last edit at 04/20/2017 02:00PM by Bee69.
