Unicubic U1 - Review and work in progress November 26, 2017 10:50AM |
Re: Unicubic U1 - Review and work in progress November 26, 2017 02:23PM |
Re: Unicubic U1 - Review and work in progress November 26, 2017 03:06PM |
vannystick
There are no obvious instructions on how to tension the belts, run the cables to the print head or what the plastic tube in the kit was for. Most of this was easy to sort out and pretty quickly I was up and running, printing the demo from the SD card, a simple tube. I spent far far too long levelling the bed. My first print created a not very round tube, so a bit more tweaking of the belts and the 'kneeling elephant' printed out pretty well.
On trying to load the file from the SD card, the printer simply locked up. I tried changing my CURA settings and making other tweaks, but ultimately I found I had no idea what firmware was on the printer. It was clearly Marlin but an older version. So a reinstall was the only way to go.
What I should have done is fire up Arduino, read the settings in a serial window and make a note of them, but I didn't. What followed was 30 minutes of installing the latest version of Marlin, followed by a week of working out the right settings! In the process i've discovered the original problem I had with loading the Boat was actually with the 'Kingston' SD card which is most certainly not genuine.
One issue I am having is lateral lamination, my layers in Z are well bonded but my parallel X/Y lines do not seem to fuse.
Re: Unicubic U1 - Review and work in progress November 27, 2017 10:40AM |
Re: Unicubic U1 - Review and work in progress November 27, 2017 11:08AM |
SteveRoy
Check that when you ask "pronterface" or "repetier" to extrude 100mm of filament that it does - within a mm or two.
The China kits are a race to the bottom - this forum and youtube are full of "how-to's" on upgrading these kits to get decent prints.
Re: Unicubic U1 - Review and work in progress April 08, 2020 01:46PM |
Re: Unicubic U1 - Review and work in progress October 26, 2021 10:00AM |
