Converting 12v to 24v January 03, 2018 01:28PM |
Re: Converting 12v to 24v January 03, 2018 10:49PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Converting 12v to 24v January 04, 2018 03:32AM |
Re: Converting 12v to 24v January 04, 2018 07:19AM |
Re: Converting 12v to 24v January 04, 2018 10:03PM |
Re: Converting 12v to 24v January 05, 2018 12:49PM |
Re: Converting 12v to 24v January 05, 2018 08:21PM |
Thereaper
why cant you get a higher amp 12v p/s to cope with the heat bed instead of changing everything to 24v!!
Re: Converting 12v to 24v January 06, 2018 12:27PM |
Re: Converting 12v to 24v January 09, 2018 08:36PM |
Re: Converting 12v to 24v January 09, 2018 09:54PM |
Re: Converting 12v to 24v January 11, 2018 07:30PM |
Re: Converting 12v to 24v January 12, 2018 03:54AM |
Re: Converting 12v to 24v January 12, 2018 09:43AM |
Re: Converting 12v to 24v January 13, 2018 04:18AM |
Cougar281
What noise are you referring to? I've read some posts about steppers making annoying high pitched noise when idle but powered, which these don't make, but they do make 'noise' when they're moving, although I'd say it's nothing annoying and is a 'noise' that I'd consider normal for operating motors. Plus the supply voltage shouldn't make a difference to them, as best I can tell, they seem to actually run off 3.3v or 5v, so a voltage regulator on the controller would be knocking the input voltage down to what they need.
Re: Converting 12v to 24v January 13, 2018 03:46PM |
Re: Converting 12v to 24v January 13, 2018 04:38PM |
Re: Converting 12v to 24v January 13, 2018 09:10PM |
