Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 01, 2019 07:42PM |
Re: Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 05, 2019 12:00PM |
Re: Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 05, 2019 12:19PM |
Re: Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 05, 2019 12:26PM |
MCcarman
Do you have the extrusion width set to a fixed value carried over from your old nozle?
Should be on Auto or something over 0.8 like 0.81.
Roberts_Clif
I would suggest with a larger nozzle diameter that when your having problems only on the thinner layer heights that higher filament temperatures may allow filament flow. Print a temperature tower.
If this fails you may need a stronger extruder stepper motor.
I will be working with a 1mm nozzle here soon so I will learn to solve these problems first hand.
Re: Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 06, 2019 12:50AM |
Re: Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 06, 2019 07:33AM |
Re: Under-extrusion with 0.8mm nozzle for layer heights below 0.4mm August 06, 2019 09:43AM |
