Re: RepRapPro's new printer kit (off-topic) May 25, 2015 08:47AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 09:06AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 09:19AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 10:09AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 10:21AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 02:11PM |
PRZ
For non contact sensors, M18 is the most common diameter, however, it is easy to find inductive in 12mm diameter at low cost.
For much higher cost, it also exists 8mm diameter sensors. Capacitive sensors, however, are more difficult to find in 12 mm diameter, but they exist in flat package.
Inductive sensor, direct from china, 2.3 GBP, postage paid ... That may take some time, however...
[www.ebay.co.uk]
Capacitive sensor, in a flat package, more difficult to install, but compact, 3.44 GBP, postage paid :
[www.ebay.co.uk]
Re: RepRapPro's Fisher Delta - OpenSCAD simulation May 25, 2015 04:47PM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 05:17PM |
Re: RepRapPro's Fisher Delta - OpenSCAD simulation May 25, 2015 05:35PM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 07:56AM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 09:12AM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 09:33AM |
droftarts
... and we may be able to reduce the wiring to the top anyway...
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 09:58AM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 10:36AM |
dc42
You could use a common wire for heater +ve and hot end fan +ve. With care over routing, you could use a common ground side wire for the 3 endstop switches. Beyond that, I've long held the belief that it makes sense to do the heater and hot end fan control on a small board on the hot end itself, especially for multiple nozzle systems - although in the absence of a Z probe mounted on the hot end, this would give little or no saving in the number of wires on a single nozzle system.
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 01:10PM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 01:22PM |
Fpex
I understand PRZ. I am building a Kossel XL by replicating what a friend is doing, and the results he gets are ok bit not what we both expected. Most design we see and try are not very stable and a crash on a Kossel can be very very catastrophic.
The fisher is small, but seems rather robust in its frame and it makes very attractive. Even I am considering taking a beta one and see how it evolves. If only I could find a spot in the house,
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 02:07PM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 03:45PM |
Fpex
PS: looks like you are using the very same design. Most defects came out for us after a month of intense use (for some work stuff) at my friend pkace. In fact we are bulding two to try and play around with both at different times.
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 03:49PM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 03:59PM |
Treito
dc42, what dimensions you can print?
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 04:04PM |
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 06:28PM |
Fpex
Btw what profiles you use (I think you mentioned already) as our problem could be using the open beams that are lighter than we anticipated.
Re: RepRapPro's new printer kit (off-topic) May 26, 2015 11:50PM |
Re: RepRapPro's new printer kit (off-topic) May 27, 2015 03:55AM |
dc42
Fpex
I use Motadis 2020 for the verticals, 2060 for 2 of the base horizontals, and 2020 for the remaining 5 horizontals. I am using the I-profile, although it wasn't the best choice because it doesn't fit the Robotdigg aluminium corners unless the slots are widened a little.
Re: RepRapPro's new printer kit (off-topic) May 27, 2015 05:44AM |
Re: RepRapPro's new printer kit (off-topic) May 27, 2015 07:52AM |
Re: RepRapPro's new printer kit (off-topic) May 28, 2015 11:03AM |
Re: RepRapPro's new printer kit (off-topic) June 02, 2015 12:16PM |
Re: RepRapPro's new printer kit (off-topic) June 02, 2015 03:08PM |
droftarts
Sally has just posted some new videos of the Fisher: [www.youtube.com] and [www.youtube.com]
Ian
RepRapPro tech support
Re: RepRapPro's new printer kit (off-topic) June 02, 2015 04:54PM |
