Printed Arms: print them before the incident! September 03, 2015 05:53PM |
Re: Printed Arms: print them before the incident! September 03, 2015 06:08PM |
Re: Printed Arms: print them before the incident! September 03, 2015 08:58PM |
Re: Printed Arms: print them before the incident! September 04, 2015 02:31AM |
Re: Printed Arms: print them before the incident! September 04, 2015 04:32AM |
Re: Printed Arms: print them before the incident! September 04, 2015 05:38AM |
Re: Printed Arms: print them before the incident! September 04, 2015 05:44AM |
PRZ
If using PLA, the pressure load is a bit more than double that with PETG, directly related to the the material stiffness. In fact, for PLA, you may need my first version, but it is cancelled. I can redo something adapted to PLA by thinning the fork root by 20/21%. Don't forget to lubricate. However, I will not test as my machine is conditioned for PETG (no part cooling) and I never use PLA. I will chamfer sides to help insertion, which I think may have been quite hard in PLA !
Re: Printed Arms: print them before the incident! September 04, 2015 06:12AM |
Re: Printed Arms: print them before the incident! September 04, 2015 06:37AM |
Re: Printed Arms: print them before the incident! September 04, 2015 06:40AM |
Re: Printed Arms: print them before the incident! September 04, 2015 07:10AM |
Re: Printed Arms: print them before the incident! September 04, 2015 07:17AM |
Re: Printed Arms: print them before the incident! September 04, 2015 08:29AM |
Re: Printed Arms: print them before the incident! September 04, 2015 09:31AM |
Re: Printed Arms: print them before the incident! September 04, 2015 11:05AM |
Re: Printed Arms: print them before the incident! September 04, 2015 11:07AM |
Re: Printed Arms: print them before the incident! September 04, 2015 11:15AM |
Re: Printed Arms: print them before the incident! September 04, 2015 11:20AM |
Great! mayby i wasnt specifik enough, but yes it was the PLA version i was looking for! thank you very much! =)Quote
PRZ
There was stl for the PETG/ABS in my first post.
STL file attached for the PLA option (less stiff), but I am not extremely confident of proper operation in PLA. I have not tested.
You may wait the tests of Greg_be on this material. PLA quality is also quite variable.
A solution in case of crack on PLA could be to lengthen the fork (and increase thickness accordingly).
[attachment 61470 Fisher_arms1setPLA.zip]
Re: Printed Arms: print them before the incident! September 04, 2015 11:25AM |
Re: Printed Arms: print them before the incident! September 04, 2015 11:30AM |
Re: Printed Arms: print them before the incident! September 05, 2015 06:03AM |
Re: Printed Arms: print them before the incident! September 05, 2015 06:29AM |
Re: Printed Arms: print them before the incident! September 10, 2015 02:02PM |
Re: Printed Arms: print them before the incident! September 10, 2015 04:10PM |
Re: Printed Arms: print them before the incident! September 27, 2015 02:36PM |
Re: Printed Arms: print them before the incident! September 27, 2015 08:25PM |
Re: Printed Arms: print them before the incident! September 28, 2015 02:30PM |
