What have you made with your Fisher. January 03, 2016 02:03PM |
Re: What have you made with your Fisher. January 03, 2016 05:42PM |
Re: What have you made with your Fisher. January 06, 2016 07:55AM |
Re: What have you made with your Fisher. January 06, 2016 08:08AM |
Re: What have you made with your Fisher. January 06, 2016 09:03AM |
Re: What have you made with your Fisher. January 06, 2016 09:10AM |
Re: What have you made with your Fisher. January 06, 2016 09:37AM |
Re: What have you made with your Fisher. January 06, 2016 09:43AM |
Re: What have you made with your Fisher. January 06, 2016 02:19PM |
DADIY
I put a couple of cable ties around the bowden tube and the electric to hold them together, it seems to help reduce the bowden tube catching and getting sandwich between the carriage and the limit switches during a home operation. I upgraded my machine to a Fisher XT so I have an even longer ~600mm bowden tube and the friction hasn't been an issue. If anything over tightening the heat-sink or brass end can increase the friction so might be worth getting a little filament and feeling on entry whether you can feel resistance.
If you dont use locktite on the ball ends they will fall off, I found that out to my peril.
After you've readjusted you might want to read the threads about 10 factor calibration and setting the config.g up properly for your machine.
Re: What have you made with your Fisher. January 07, 2016 05:55AM |
Re: What have you made with your Fisher. January 07, 2016 06:56AM |
Re: What have you made with your Fisher. January 07, 2016 07:34AM |
Caribou
Well thanks again DADIY I finally got a quality print out last night and printed something I wanted to do from the beginning
The quality improvement was amazing. I downloaded the config for slicer from Github and apart from reducing speeds I changed nothing. I will reprint a raspberry PI case that I had done over the next couple of days and post the results of that - very happy man at the moment
poorly shot "blair witch" style video of my fisher in action
video of the bearing being printed...
Re: What have you made with your Fisher. January 07, 2016 07:47AM |
Re: What have you made with your Fisher. January 07, 2016 10:06AM |
Re: What have you made with your Fisher. January 07, 2016 10:19AM |
Re: What have you made with your Fisher. January 19, 2016 01:23PM |
Re: What have you made with your Fisher. August 01, 2016 10:38AM |
DADIY
If your using Slic3r did you download the precreated profile or create your own? - the official one is here - [github.com]
Re: What have you made with your Fisher. August 01, 2016 10:58AM |
Re: What have you made with your Fisher. March 05, 2017 05:35PM |
Re: What have you made with your Fisher. March 08, 2017 03:57AM |
Re: What have you made with your Fisher. March 08, 2017 04:19AM |
Re: What have you made with your Fisher. March 08, 2017 12:43PM |
Re: What have you made with your Fisher. March 10, 2017 03:17PM |
Re: What have you made with your Fisher. March 13, 2017 05:31PM |
Re: What have you made with your Fisher. March 20, 2017 05:33PM |
Re: What have you made with your Fisher. March 23, 2017 02:29PM |
Re: What have you made with your Fisher. March 26, 2017 05:08PM |
Re: What have you made with your Fisher. April 19, 2017 04:18PM |
Re: What have you made with your Fisher. April 20, 2017 04:25AM |
Re: What have you made with your Fisher. April 21, 2017 04:51PM |
