Dual X carraige X2 stepper pin define July 06, 2018 08:15PM |
#define X2_ENABLE_PIN 44 #define X2_STEP_PIN 42 #define X2_DIR_PIN 40
Re: Dual X carraige X2 stepper pin define July 07, 2018 07:03PM |
#define X_MIN_POS 0 #define X_MAX_POS X_BED_SIZE #define MANUAL_X_HOME_POS -37
#define X2_MIN_POS 45 // set minimum to ensure second x-carriage doesn't hit the parked first X-carriage #define X2_MAX_POS 259 // set maximum to the distance between toolheads when both heads are homed #define X2_HOME_DIR 1 // the second X-carriage always homes to the maximum endstop position #define X2_HOME_POS X2_MAX_POS // default home position is the maximum carriage position #define DEFAULT_DUAL_X_CARRIAGE_MODE DXC_AUTO_PARK_MODE
Re: Dual X carraige X2 stepper pin define July 07, 2018 08:29PM |
Re: Dual X carraige X2 stepper pin define July 07, 2018 11:53PM |
machine limits vs endstop locations. July 08, 2018 04:36AM |
Idle carriage will not park. July 08, 2018 08:30AM |
M205 S1 ; Dual X carriage auto park mode.into the start script in S3d.
Re: machine limits vs endstop locations. July 08, 2018 08:43AM |
moose4621
My machine has the end stop 37mm to the left of the build plate so the whole hotend assy is clear of the build plate.
Re: Idle carriage will not park. July 08, 2018 05:58PM |
// Manually set the home position. Leave these undefined for automatic settings. // For DELTA this is the top-center of the Cartesian print volume. #define MANUAL_X_HOME_POS 37 #define MANUAL_Y_HOME_POS 10 //#define MANUAL_Z_HOME_POS 0Are these settings the same as issuing an M206?
Re: Idle carriage will not park. July 08, 2018 09:14PM |
#define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0Which limited my travel to withing the bed.
Re: Idle carriage will not park. July 12, 2018 06:20AM |
Re: Idle carriage will not park. October 01, 2018 12:17PM |
