G28 when using a BLTouch issues. August 16, 2019 10:02PM |
Re: G28 when using a BLTouch issues. August 17, 2019 03:31PM |
Re: G28 when using a BLTouch issues. August 17, 2019 04:32PM |
Re: G28 when using a BLTouch issues. August 17, 2019 07:30PM |
People are strange (human nature) that no one wants to be the first to respond. When you get it hooked up I would love to know because of the two issues I mentioned I can't figure out what it could be or how to fix them (Atom is a pita in this department as it lacks a search through all files feature and if it has it it is buried somewhere). Marlin 2.0, as you know, has so many files now it is hard to go through each one trying to find something. I did head to G28 but I got lost but in Marlin 1.0, and before, it was easy to find and modify.Quote
Roberts_Clif
This thread is being read, I have never used a BLTouch.
I have used a low profile proximity sensor TL-W3MC2 with Marlin 2.0 that works.
I have setup a Marlin 2.0 for BLTouch though it has never been tested. Was going to test on my MPCNC after ordering a BLTouch.
An did not respond because of such, did not think you would want untested BLTouch Marlin 2.0 routine settings from a MPCNC Marlin 2.0 configuration...
Re: G28 when using a BLTouch issues. August 18, 2019 09:46AM |
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN //#define FIX_MOUNTED_PROBE #define BLTOUCH #if ENABLED(BLTOUCH) #define BLTOUCH_DELAY 375 // (ms) Enable and increase if needed #endif #define PROBING_HEATERS_OFF // Turn heaters off when probing #if ENABLED(PROBING_HEATERS_OFF) //#define WAIT_FOR_BED_HEATER // Wait for bed to heat back up between probes (to improve accuracy) #endif #define PROBING_FANS_OFF // Turn fans off when probing #define PROBING_STEPPERS_OFF // Turn steppers off (unless needed to hold position) when probing //#define DELAY_BEFORE_PROBING 200 // (ms) To prevent vibrations from triggering piezo sensors
Re: G28 when using a BLTouch issues. August 18, 2019 08:15PM |
I haven't even gotten to the point of probing yet as I got sick and it is over 85f in that room.Quote
Roberts_Clif
Well if you want to look at what I have before testing here
If I remember after test I will Post what my conclusions are.
Re: G28 when using a BLTouch issues. August 19, 2019 07:25AM |
Re: G28 when using a BLTouch issues. August 19, 2019 07:36AM |
Re: G28 when using a BLTouch issues. August 22, 2019 09:13AM |
Re: G28 when using a BLTouch issues. August 23, 2019 10:19AM |
Re: G28 when using a BLTouch issues. August 23, 2019 12:23PM |
Roberts_Clif
Are you referring to one these
#define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
#define Z_CLEARANCE_MULTI_PROBE 5 // Z Clearance between multiple probes
#define Z_AFTER_PROBING 10 // Z position after probing is done
