Could use some help with step calculations December 11, 2019 09:03AM |
// variables to calculate steps #define XYZ_FULL_STEPS_PER_ROTATION 200 // These are the setting for the stock Stepper Motors, pulleys and Belts on the AnyCubic Kossel #define XYZ_MICROSTEPS 16 #define XYZ_BELT_PITCH 2 #define XYZ_PULLEY_TEETH 20 // delta speeds must be the same on xyz #define DEFAULT_XYZ_STEPS_PER_UNIT ((XYZ_FULL_STEPS_PER_ROTATION) * (XYZ_MICROSTEPS) / double(XYZ_BELT_PITCH) / double(XYZ_PULLEY_TEETH)) #define DEFAULT_AXIS_STEPS_PER_UNIT { DEFAULT_XYZ_STEPS_PER_UNIT, DEFAULT_XYZ_STEPS_PER_UNIT, DEFAULT_XYZ_STEPS_PER_UNIT, 98 } // default steps per unit for Kossel (GT2, 20 tooth)Unfortunately my parts are coming out slightly smaller than intended. especially in X and Y (probably Z as well, as it's a delta) - to get the exact size I have increase the scale in the slicer by 1.012.
Re: Could use some help with step calculations December 11, 2019 09:11AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Could use some help with step calculations December 11, 2019 09:39AM |
Re: Could use some help with step calculations December 12, 2019 01:53AM |
Re: Could use some help with step calculations December 12, 2019 02:01PM |
