Marlin 2.0 newbie questions March 18, 2020 05:46PM |
Re: Marlin 2.0 newbie questions March 18, 2020 10:31PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Marlin 2.0 newbie questions March 18, 2020 10:43PM |
Re: Marlin 2.0 newbie questions March 19, 2020 03:35PM |
Dust
Some hints
The sd card that comes with these board is complete garbage, do not use them.
The two boards SKR V1.3 and the Mini DIP V1.0. are very different processors and the upload procedure is different.
For the SKR V1.3 you put the sd card into the controller and plug the controller into the pc. (if you just have usb cables and now power supply you need to set the power jumper to USB, but make sure you put it back when you plug in powersupply.) The SD card should show on the computer as a drive. The firmware upload script looks for the drive that is the SD card in your controller. It needs a volume label REARM or the file FIRMWARE.CUR to locate where to put the new firmware file.
The SKR V1.3 also actually only loads the firmware on reboot of the controller. So you need to upload then reset or re-power the board. Then give it 30 seconds or so to actually update the firmware.
The Mini Dip is done manually. You have to mount the SD card in a USB/SD card reader on your computer and manually copy the compiled firmware to it. Then put the sd card into the controller and reboot/re-power it.
Re: Marlin 2.0 newbie questions March 19, 2020 11:37PM |
Re: Marlin 2.0 newbie questions March 28, 2020 12:38PM |
