I am using a Ender 3 V2
yesterday I installed BL Touch module from Antclabs.
I changed the firmware to following from Creality site:
"4.2.2 Ender-3 v2 Marlin2.0.1 BLtouchV1.1.1without adapter board firmware"
My board version is 4.2.2 and the JST connector from BL touch is directly connected to the board BL touch port.
Then I changed the Z-offset to -3.1mm
Auto leveling woks fine and G29 command goes does it fine.
But my prints does not start.
I tried both from SD card and directly from USB
Heating and leveling/homing part works. But right at the printing phase it stops.
I see on terminal following output where the error starts:
Send: N9 G28*26
Recv: TT::200.56200.56 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6969 BB@@::2424
Recv:
Recv: echo:busy: processing
Recv:
Recv: TT::200.52200.52 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6969 BB@@::2424
Recv:
Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::8181 BB@@::2424
Recv:
Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7979 BB@@::2424
Recv:
Recv: TT::200.07200.07 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7676 BB@@::2525
Recv:
Recv: TT::200.56200.56 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6464 BB@@::2525
Recv:
Recv: TT::200.52200.52 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6565 BB@@::2525
Recv:
Recv: TT::200.03200.03 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7777 BB@@::2525
Recv:
Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7575 BB@@::2626
Recv:
Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7474 BB@@::2626
Recv:
Recv:
Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7373 BB@@::2626
Recv:
Recv: TT::200.03200.03 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7272 BB@@::2626
Recv:
Recv: TT::200.00200.00 //200.00200.00 BB::60.0160.01 //60.0060.00 @@::7373 BB@@::2222
Recv:
Recv: X:155.00 Y:130.00 Z:13.00 E:0.00 Count X:12400 Y:10400 Z:5200
Recv: ok
Send: N10 G1 Z2.0 F3000*42
Recv: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Recv: ok
Send: N11 G1 X0.1 Y20 Z0.3 F5000.0*30
Recv: ok
Send: N12 G1 X0.1 Y200.0 Z0.3 F1500.0 E15*83
Recv: ok
Send: N13 G1 X0.4 Y200.0 Z0.3 F5000.0*55
Recv: ok
Send: N14 G1 X0.4 Y20 Z0.3 F1500.0 E30*121
Recv: ok
what is the problem with setup ?
I am not sure about the correct Z-offset but I guess this is not the reason for the error.
