YB2004D screen is on, but doesn't display anything November 14, 2021 03:22AM |
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 03:34AM |
Admin Registered: 13 years ago Posts: 7,003 |
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 03:58AM |
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 07:04AM |
Dust
Found this advert for this lcd
Includes the image
this lists what all pins are, but is a little small to read
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 07:51AM |
EXP1 1 2 3 4 5 6 7 8 9 10 +5v Gnd DB7 DB6 DB5 DB4 RS E ? ? (? is unreadable) expected +5v Gnd DB7 DB6 DB5 DB4 RS E enc BEEPER
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 08:57AM |
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 09:28AM |
Roberts_Clif
This happened to me.
I found several ways to correct.
[attachment 118866 Both-50.jpg]
The easiest is to carefully remove the plastic Key rotate it 180 degrees and replace by carefully skidding it back over the pins.
The hardest is to remake the cables like I did in to attached photo by inverting the cable on one side.
Re: YB2004D screen is on, but doesn't display anything November 14, 2021 10:54AM |
Re: YB2004D screen is on, but doesn't display anything November 15, 2021 12:39AM |
Roberts_Clif
Both the connectors in top most photo this is the new LCD from BIgTree the Next photo down is my original controller from Hictop a 2004 LCD,
I think hictop 2004 LCD is a clone of the RepRap Smart controller. THe hictop 2004 LCD also has right angle Connectors.
Look at the Red Cable wire and note which side it is on.
You will also note the both connectors on the big tree controller are the opposite of the 2004 LCD Hictop contoller
Any way this is what I had to do to fix the problem, Sorry also missed a little on my first post and correct before your last post.
Re: YB2004D screen is on, but doesn't display anything November 15, 2021 06:42AM |
Re: YB2004D screen is on, but doesn't display anything November 16, 2021 02:51AM |
Roberts_Clif
On the back of the LCD controller there is a contrast control Have you tried to adjust it.
if not then
Post your Marlin Config will have a look.
Re: YB2004D screen is on, but doesn't display anything November 16, 2021 08:31AM |
Re: YB2004D screen is on, but doesn't display anything November 17, 2021 09:30AM |
Roberts_Clif
On the back of your LCD there is a contrast control potentiometer turning it will adjust the LCD contrast.
[attachment 118871 contrast.jpg]
Re: YB2004D screen is on, but doesn't display anything November 19, 2021 07:39AM |
Re: YB2004D screen is on, but doesn't display anything November 19, 2021 10:43AM |
I did...Quote
Roberts_Clif
Then if you post your Marlin configuration file to a share like google drive and post a link.
I would take a look at your configuration, an may spot a configuration error...
Re: YB2004D screen is on, but doesn't display anything November 20, 2021 08:23AM |
Re: YB2004D screen is on, but doesn't display anything November 20, 2021 10:22AM |
I'm sorry here is the full unzipped root under a mega linkQuote
Roberts_Clif
I cannot retrieve Marlin from anything you have posted???
Re: YB2004D screen is on, but doesn't display anything November 22, 2021 08:28AM |
// ************************************************************************************************************************ // The RepRapDiscount Smart Controller (Red PC // [reprap.org] #define REPRAP_DISCOUNT_SMART_CONTROLLER // CL: Stock HICi3 20x4 LCD controller #define NEWPANEL // enable this if you have a click-encoder panel // ************************************************************************************************************************
Re: YB2004D screen is on, but doesn't display anything November 28, 2021 12:17AM |
Roberts_Clif
Your Marlin appears correct though my code has an additional line.
Re: YB2004D screen is on, but doesn't display anything November 30, 2021 08:13AM |
