Getting error when uploading to printer board
February 21, 2016 01:15AM
This is the error i am getting and I am completly lost on this. Any help would be awesomeconfused smiley
Arduino: 1.6.7 (Windows 7), Board: "Arduino Mega ADK"
In file included from sketch\Marlin.h:21:0,
from sketch\temperature.cpp:32:
fastio.h:45: error: pasting "DIO" and "-" does not give a valid preprocessing token
#define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0)
sketch\fastio.h:68:23: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
sketch\temperature.cpp:1249:24: note: in expansion of macro 'WRITE'
if(soft_pwm_1 > 0) WRITE(HEATER_1_PIN,1); else WRITE(HEATER_1_PIN,0);
fastio.h:34: error: pasting "DIO" and "-" does not give a valid preprocessing token
{DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\
sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C'
fastio.h:39: error: pasting "DIO" and "-" does not give a valid preprocessing token
{DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\
fastio.h:30: error: pasting "DIO" and "-" does not give a valid preprocessing token
#define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC'
sketch\temperature.cpp:1249:52: note: in expansion of macro 'WRITE'
sketch\temperature.cpp:1271:30: note: in expansion of macro 'WRITE'
if(soft_pwm_1 < pwm_count) WRITE(HEATER_1_PIN,0);
sketch\temperature.cpp: In function 'void __vector_22()':
fastio.h:45: error: 'DIO' was not declared in this scope
pins.h:687: error: unable to find numeric literal operator 'operator"" _RPORT'
#define HEATER_1_PIN -1
sketch\fastio.h:45:44: note: in definition of macro '_WRITE'
sketch\temperature.cpp:1249:30: note: in expansion of macro 'HEATER_1_PIN'
pins.h:687: error: unable to find numeric literal operator 'operator"" _WPORT'
sketch\fastio.h:34:51: note: in definition of macro '_WRITE_C'
pins.h:687: error: unable to find numeric literal operator 'operator"" _PIN'
sketch\fastio.h:17:26: note: in definition of macro 'MASK'
#define MASK(PIN) (1 << PIN)
sketch\fastio.h:39:51: note: in definition of macro '_WRITE_C'
sketch\fastio.h:30:48: note: in definition of macro '_WRITE_NC'
sketch\fastio.h:30:105: note: in definition of macro '_WRITE_NC'
sketch\temperature.cpp:1249:58: note: in expansion of macro 'HEATER_1_PIN'
sketch\temperature.cpp:1271:36: note: in expansion of macro 'HEATER_1_PIN'
exit status 1
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Re: Getting error when uploading to printer board
February 21, 2016 03:08AM
Why are you using a "Arduino Mega ADK"
Thats a very weird non standard choice, should just be a "Arduino Mega" ADK is Accessory Development Kit.
The ADK has a USB host interface to connect with Android based phones....
February 21, 2016 11:01AM
Ok... I have figured out my problem. Thanks for the mention of the ADK I accidentally selected the wrong board, meant to choose the one above. Now I have a new issue all together. I will post it separate from this
