Hi!
I recently made some mods to my ORD MH3000R1 and I had to learn some Marlin in the process, witch is cool but I'm still a novice..
So I downgraded to 2 heads instead of 5, but upgraded those 2 heads with better heating blocks, nozzles and insulation. I managed to PID the thermistors on the heads and now I get this error:
Error: Coolant temperature exceeds max, extruders switched off MAXTEMP triggered !''
it comes from the new thermocouple in the cooling block, cause this machine has a water cooling system with a pump, radiator and a Peltier. I could not use the cooling block that had the original sensor, witch I think is also a thermocouple because of the metal clamps on the leads, so I installed a new one in another block. The new thermocouple is plugged in the same pin as the original one.
In ORDs' configuration.h,
''#define TEMP_SENSOR_LC 7''
(witch in thermistortables.h is a 100k Honeywell 135-104LAG-J01) but my new thermocouple is a K type WRN-02 (0-600°C)
I've been googling for days and learned some stuff along the way but it didn't get me printing yet.
I haven't printed anything for the last 2 weeks, I'm craving it badly!!! smiling smiley
Please help
Thanks
