Z height wrong after z probing July 29, 2016 12:22PM |
G21 (set units to mm) G90 (set positioning to absolute) M82 (set extruder to absolute) (**** begin homing ****) G28 X G28 Y F4000 (home XY axes) G29 (bed level) (**** end homing ****) M109 S208 (Heat extruder) ; -- end of START GCODE -
Re: Z height wrong after z probing July 29, 2016 02:08PM |
Re: Z height wrong after z probing July 30, 2016 04:12PM |
Re: Z height wrong after z probing July 30, 2016 04:52PM |
Re: Z height wrong after z probing July 31, 2016 04:32AM |
EEPROM is disabled in my config, so it should not affect the leveling procedure.Quote
Roxy
Did you do a M502 and M500 pair of commands? It kind of sounds like you have a Z_Offset saved in your EEPROM.
Roxy
The entire bed leveling system has been rewritten in www.github.com/MarlinFirmware/Marlin/devel_ubl. You can try that as a solution.
sketch/Marlin_main.cpp: In function 'void gcode_T(uint8_t)': Marlin_main.cpp:6223: error: 'class Planner' has no member named 'bed_level_matrix' offset_vec.apply_rotation(planner.bed_level_matrix.transpose(planner.bed_level_matrix)); ^ Marlin_main.cpp:6223: error: 'class Planner' has no member named 'bed_level_matrix' offset_vec.apply_rotation(planner.bed_level_matrix.transpose(planner.bed_level_matrix)); ^ exit status 1 'class Planner' has no member named 'bed_level_matrix'
Re: Z height wrong after z probing July 31, 2016 09:42AM |
Re: Z height wrong after z probing July 31, 2016 10:58AM |
sketch/Marlin_main.cpp: In function 'void gcode_T(uint8_t)': Marlin_main.cpp:6248: error: 'class bed_leveling' has no member named 'active' if (bed_leveling_mesh.active()) { ^ Marlin_main.cpp:6251: error: 'xydiff' was not declared in this scope current_position[Z_AXIS] += bed_leveling_mesh.get_z_correction(xpos + xydiff[X_AXIS], ypos + xydiff[Y_AXIS]) - bed_leveling_mesh.get_z_correction(xpos, ypos); ^ Marlin_main.cpp:6259: error: 'xydiff' was not declared in this scope current_position[X_AXIS] += xydiff[X_AXIS]; ^ exit status 1 'class bed_leveling' has no member named 'active'
Re: Z height wrong after z probing July 31, 2016 12:10PM |
Re: Z height wrong after z probing July 31, 2016 12:41PM |
M80 ok G28 echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing X:200.00 Y:190.00 Z:65.00 E:0.00 Count X: 16000 Y:15200 Z:166400 ok G29 P0 T M A Unified Bed Leveling System activated. Mesh zeroed. echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing d from first point: -6.110357 c: -5.440312 d from second point: -6.110357 c: -5.339140 d from third point: -6.110356 c: -0.987578 Bed Topography Report: (0,9) (9,9) (22,165) (199,165) -5.49565 -4.82179 -4.14793 -3.47406 -2.80020 -2.12633 -1.45247 -0.77861 -0.10474 0.56912 -5.48170 -4.80783 -4.13397 -3.46010 -2.78624 -2.11238 -1.43851 -0.76465 -0.09078 0.58308 -5.46774 -4.79387 -4.12001 -3.44615 -2.77228 -2.09842 -1.42455 -0.75069 -0.07683 0.59704 -5.45378 -4.77992 -4.10605 -3.43219 -2.75832 -2.08446 -1.41060 -0.73673 -0.06287 0.61100 -5.43982 -4.76596 -4.09209 -3.41823 -2.74437 -2.07050 -1.39664 -0.72277 -0.04891 0.62495 -5.42586 -4.75200 -4.07814 -3.40427 -2.73041 -2.05654 -1.38268 -0.70882 -0.03495 0.63891 -5.41191 -4.73804 -4.06418 [-3.39031] -2.71645 -2.04259 -1.36872 -0.69486 -0.02099 0.65287 -5.39795 -4.72408 -4.05022 -3.37636 -2.70249 -2.02863 -1.35476 -0.68090 -0.00704 0.66683 -5.38399 -4.71013 -4.03626 -3.36240 -2.68853 -2.01467 -1.34081 -0.66694 0.00692 0.68079 -5.37003 -4.69617 -4.02230 -3.34844 -2.67458 -2.00071 -1.32685 -0.65298 0.02088 0.69474 (22,16) (199,16) (0,0) (9,0) ok
Re: Z height wrong after z probing July 31, 2016 12:53PM |
Re: Z height wrong after z probing July 31, 2016 03:07PM |
Re: Z height wrong after z probing August 01, 2016 05:15PM |
Re: Z height wrong after z probing August 01, 2016 05:25PM |
VBen
But i found a Bug, the compensation does not work under several conditions with manual control by LCD
Steps to reproduce:
1. A Z-max endstop setup is used for homing
2. after homing Z=0 should be some mm over the bed.
Re: Z height wrong after z probing August 01, 2016 05:34PM |
Re: Z height wrong after z probing August 01, 2016 07:03PM |
Re: Z height wrong after z probing August 02, 2016 04:39PM |
VBen
Steps to reproduce:
3. autolevel via G29 P0 T M A
4. activate again with G29 A
5. lower z by the LCD to Z=0 on display
6. the nozzle is now some mm over the bed and the compensation feature does not work for moves along x or y axis using the LCD panel
to get it work:
7. Execute G0 Z1
8. the nozzle is going down, the display shows Z=1
9. Use the lcd to move along x or y axis . These moves are now compensated
Re: Z height wrong after z probing August 02, 2016 07:48PM |
Re: Z height wrong after z probing August 03, 2016 02:14PM |
G29 P 0 T M A Unified Bed Leveling System activated. Mesh zeroed. echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing raw get_z_correction(23.00,140.00)=0.000000 >>>---> 0.000000 raw get_z_correction(23.00,20.00)=0.000000 >>>---> 0.000000 raw get_z_correction(150.00,20.00)=0.000000 >>>---> 0.000000 echo:busy: processing d from first point: -5.514165 c: -5.274687 d from second point: -5.514165 c: -5.408281 d from third point: -5.514165 c: -4.946562 Bed Topography Report: (0,9) (9,9) (22,165) (199,165) -5.25049 -5.17899 -5.10749 -5.03599 -4.96449 -4.89299 -4.82149 -4.74999 -4.67849 -4.60699 -5.26892 -5.19742 -5.12592 -5.05442 -4.98292 -4.91142 -4.83992 -4.76842 -4.69692 -4.62542 -5.28735 -5.21585 -5.14435 -5.07285 -5.00135 -4.92985 -4.85835 -4.78685 -4.71535 -4.64385 -5.30578 -5.23428 -5.16278 -5.09128 -5.01978 -4.94828 -4.87679 -4.80529 -4.73379 -4.66229 -5.32421 -5.25271 -5.18122 -5.10972 -5.03822 -4.96672 -4.89522 -4.82372 -4.75222 -4.68072 -5.34265 -5.27115 -5.19965 -5.12815 -5.05665 -4.98515 -4.91365 -4.84215 -4.77065 -4.69915 -5.36108 -5.28958 -5.21808 [-5.14658] -5.07508 -5.00358 -4.93208 -4.86058 -4.78908 -4.71758 -5.37951 -5.30801 -5.23651 -5.16501 -5.09351 -5.02201 -4.95051 -4.87901 -4.80751 -4.73601 -5.39794 -5.32644 -5.25494 -5.18344 -5.11194 -5.04044 -4.96894 -4.89744 -4.82594 -4.75444 -5.41637 -5.34487 -5.27337 -5.20187 -5.13037 -5.05887 -4.98737 -4.91587 -4.84437 -4.77287 (22,16) (199,16) (0,0) (9,0) ok M111 S128 echoEBUG:ADJUSTMENTS ok M114 X:88.50 Y:74.50 Z:15.00 E:0.00 Count X: 7080 Y:5960 Z:38400 ok G29 A Unified Bed Leveling System activated. ok NOW Moving up and down with the encoder on LCD the nozzle is much higher then 3mm over the bed raw get_z_correction(88.50,74.50)=-5.109477 >>>---> 0.000000 buffer_line( 88.50, 74.50, 7.000000) >>>---> [0.000000] (88.50, 74.50, 7.000000) raw get_z_correction(88.50,74.50)=-5.109477 >>>---> 0.000000 buffer_line( 88.50, 74.50, 3.000000) >>>---> [0.000000] (88.50, 74.50, 3.000000) M114 X:88.50 Y:74.50 Z:3.00 E:0.00 Count X: 7080 Y:5960 Z:7680 ok G0 Z3 Mesh scaling factor set for Z-Height 3.00 to 0.70 [Fade=10.00] raw get_z_correction(88.50,74.50)=-5.109477 >>>---> -3.576633 buffer_line( 88.50, 74.50, 3.000000) >>>---> [-3.576633] (88.50, 74.50, -0.576633) ok M114 X:88.50 Y:74.50 Z:3.00 E:0.00 Count X: 7080 Y:5960 Z:-1476 ok NOW after G0 move the height is correct and the level compensation works for example a move along the X-Axis with the encoder raw get_z_correction(22.00,74.50)=-5.351243 >>>---> -3.745870 buffer_line( 22.00, 74.50, 3.000000) >>>---> [-3.745870] (22.00, 74.50, -0.745870) raw get_z_correction(182.00,74.50)=-4.769549 >>>---> -3.338685 buffer_line( 182.00, 74.50, 3.000000) >>>---> [-3.338685] (182.00, 74.50, -0.338685)
Re: Z height wrong after z probing August 03, 2016 03:26PM |
Re: Z height wrong after z probing August 03, 2016 04:56PM |
Roxy
The Fade_Correction factor is done in the G0 & G1 handler for efficiency. The printer only changes layers occasionally. So it saves a lot of CPU cycles by only doing it there instead of on every move. But there are a few other places where it has to be done also. I must have missed one in the LCD movements.
If you do a G29 P 0 T M A and just use PronterFace to move the nozzle around on the bed, is everything OK? I'm hoping the answer is "Yes!" because it won't be difficult to find the LCD problem.
SENT: G91 SENT: G1 Z1.0 F200 SENT: G90
--- a/Marlin/Bed_Leveling.h +++ b/Marlin/Bed_Leveling.h @@ -169,7 +169,7 @@ enum MBLStatus { MBL_STATUS_NONE = 0, MBL_STATUS_HAS_MESH_BIT = 0, MBL_STATUS_AC #if ENABLED(DEBUG_LEVELING_FEATURE) if (DEBUGGING(MESH_ADJUST)) { - SERIAL_ECHO("??? Yikes!!! NAN in get_z_correction( "); + SERIAL_ECHO("??? Yikes!! NAN in get_z_correction( "); SERIAL_ECHO(x0); SERIAL_ECHO(", "); SERIAL_ECHO(y0); @@ -185,4 +185,4 @@ enum MBLStatus { MBL_STATUS_NONE = 0, MBL_STATUS_HAS_MESH_BIT = 0, MBL_STATUS_AC #endif // UNIFIED_BED_LEVELING_FEATURE #endif
Re: Z height wrong after z probing August 03, 2016 08:31PM |
