Setting Z axis speed February 02, 2017 08:20AM |
Re: Setting Z axis speed February 02, 2017 12:07PM |
Re: Setting Z axis speed February 02, 2017 02:29PM |
Re: Setting Z axis speed February 02, 2017 02:39PM |
Re: Setting Z axis speed February 02, 2017 03:07PM |
Re: Setting Z axis speed February 02, 2017 04:34PM |
Re: Setting Z axis speed February 02, 2017 04:54PM |
Re: Setting Z axis speed February 02, 2017 05:14PM |
Re: Setting Z axis speed February 02, 2017 05:45PM |
Re: Setting Z axis speed February 03, 2017 09:21AM |
Re: Setting Z axis speed February 03, 2017 09:36AM |
Re: Setting Z axis speed February 03, 2017 11:53AM |
Re: Setting Z axis speed February 03, 2017 11:58AM |
Re: Setting Z axis speed February 03, 2017 01:04PM |
Re: Setting Z axis speed February 03, 2017 01:36PM |
Re: Setting Z axis speed February 03, 2017 01:44PM |
DOYT
So, let me explain to you guys how I solved the first problem. I know that for many of you this is obvious but for many beginners this is a real issue. If you want to set the speed of a specific axes, first you should know that the speed you set in firmware is different from that one in your host(Repetier in my case) and it's different from the speed set in LCD. When you set the speed on the firmware, the setting applies only when you home de printer. If you try to control it from LCD or by Host, you'll se that the setting does not apply.
Re: Setting Z axis speed March 26, 2023 01:32PM |
