servo autobed levelling
Posted by rohit939
May 18, 2017 03:19PM
hello,
i'm trying to use servo
i configured everything like offsets from extruder, probing points,
when i give G29 command
servo extends and then probes to first point, and then it doesnt retract and keeps moving from one point to another
i want to retract my servo at every probing point so i can avoid any crash.
please help,
my servo doesnt retract like it happens in this video [www.youtube.com]
Edited 1 time(s). Last edit at 05/18/2017 03:23PM by rohit939.
Re: servo autobed levelling
May 19, 2017 10:44AM
It depends on which auto bed leveling you are using... But you can usually specify an 'E' option to engage and dis-engage the Z-Probe.
But really... You typically get better measurements if you leave the probe deployed. You are better off setting the various numbers better.
#define Z_CLEARANCE_DEPLOY_PROBE
#define Z_CLEARANCE_BETWEEN_PROBES
Edited 1 time(s). Last edit at 05/19/2017 10:47AM by Roxy.
June 12, 2017 03:33PM
these are not available in latest firmware,
June 12, 2017 07:05PM
Leave it down to probe all the points, its more accurate that way.
June 13, 2017 08:36AM
I had all kinds of challenges with the latest Marlin firmware getting this to work. I then loaded V1.1.0 RC8 and now everything works a charm. Might want to give that a try.
Edited 1 time(s). Last edit at 06/13/2017 08:36AM by RickRap.
