Setting RGB LED values on boot June 04, 2017 11:26AM |
Re: Setting RGB LED values on boot June 05, 2017 09:25AM |
Admin Registered: 13 years ago Posts: 7,007 |
#if ENABLED(RGB_LED) || ENABLED(RGBW_LED) SET_OUTPUT(RGB_LED_R_PIN); SET_OUTPUT(RGB_LED_G_PIN); SET_OUTPUT(RGB_LED_B_PIN); #if ENABLED(RGBW_LED) SET_OUTPUT(RGB_LED_W_PIN); #endif #endif
#if ENABLED(RGB_LED) || ENABLED(RGBW_LED) SET_OUTPUT(RGB_LED_R_PIN); OUT_WRITE(RGB_LED_R_PIN, HIGH); // turn it on SET_OUTPUT(RGB_LED_G_PIN); OUT_WRITE(RGB_LED_G_PIN, HIGH); // turn it on SET_OUTPUT(RGB_LED_B_PIN); OUT_WRITE(RGB_LED_B_PIN, HIGH); // turn it on #if ENABLED(RGBW_LED) SET_OUTPUT(RGB_LED_W_PIN); OUT_WRITE(RGB_LED_R_PIN, LOW); // turn it off OUT_WRITE(RGB_LED_G_PIN, LOW); // turn it off OUT_WRITE(RGB_LED_B_PIN, LOW); // turn it off OUT_WRITE(RGB_LED_W_PIN, HIGH); // turn it on #endif #endif
Re: Setting RGB LED values on boot June 05, 2017 09:28AM |
Re: Setting RGB LED values on boot June 06, 2017 06:23AM |
