1.1.5 getting mesh bed leveling working September 06, 2017 12:52PM |
Re: 1.1.5 getting mesh bed leveling working September 06, 2017 04:49PM |
Re: 1.1.5 getting mesh bed leveling working September 06, 2017 05:33PM |
Re: 1.1.5 getting mesh bed leveling working September 06, 2017 08:08PM |
Re: 1.1.5 getting mesh bed leveling working September 07, 2017 11:13AM |
Re: 1.1.5 getting mesh bed leveling working September 07, 2017 05:49PM |
Re: 1.1.5 getting mesh bed leveling working September 07, 2017 05:50PM |
Re: 1.1.5 getting mesh bed leveling working September 08, 2017 11:47PM |
Re: 1.1.5 getting mesh bed leveling working September 14, 2017 11:05AM |
Roberts_Clif
// The Z probe minimum outer margin (to validate G29 parameters).
#define MIN_PROBE_EDGE 10
Re: 1.1.5 getting mesh bed leveling working September 14, 2017 11:17AM |
JustSumGuy
ok.........how does any form of auto bed leveling work with no probe?
Re: 1.1.5 getting mesh bed leveling working September 14, 2017 02:26PM |
Re: 1.1.5 getting mesh bed leveling working September 14, 2017 03:11PM |
gdahilig
Roberts_Clif
I don't quite understand the comment. What does the MIN_PROBE_EDGE do?
gene
Re: 1.1.5 getting mesh bed leveling working September 14, 2017 03:21PM |
JustSumGuy
There is not enough room in the cube frame to install a probe that I can work out yet.
Re: 1.1.5 getting mesh bed leveling working September 16, 2017 12:35PM |
Re: 1.1.5 getting mesh bed leveling working September 16, 2017 12:41PM |
Re: 1.1.5 getting mesh bed leveling working September 17, 2017 05:04AM |
JustSumGuy
I would loose some build space if I put it beside the head (Either side), my fan is in front and built to actually go under the front of the frame and stick out of the cube.
I am looking at a way to put it in between the rails behind the head.... but that's looking to be a fairly major redesign....
Re: 1.1.5 getting mesh bed leveling working September 19, 2017 04:39PM |
leadinglights
JustSumGuy
If you must use a proximity sensor to do the z probing the only one worth considering is DC42s IR sensor which should be small and light enough for anybodies requirement. OTOH, unless you have philosophical prejudices against nozzle contact sensors you could consider Piezo sensors [forums.reprap.org]
Mike
