Z axis Homing Issue November 09, 2017 04:43PM |
Re: Z axis Homing Issue November 09, 2017 07:12PM |
Re: Z axis Homing Issue November 09, 2017 09:54PM |
Roberts_Clif
Are these set
#define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//and
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to same logic as "Z_MIN_ENDSTOP_INVERTING".
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
//and must have this line
#define FIX_MOUNTED_PROBE
Re: Z axis Homing Issue November 10, 2017 12:44AM |
Re: Z axis Homing Issue November 10, 2017 09:01AM |
Re: Z axis Homing Issue November 10, 2017 10:50AM |
Roberts_Clif
I am using a TL-W3MC2 using a Operating voltage range 10 to 30 VDC sensor which is powered with 5V, 1st sensor a SN04-N 6V was too bulky.
[www.ia.omron.com]
I have stopped at Marlin 1.1.5 temporally, as I had problems with Marlin 1.1.6 flashing weird, not working and almost bricking controller.
Not actually blaming Marlin 1.1.6 just made me nervous and returned to 1.1.5 as it was working best of all versions, with the features I liked and used.
Bed Leveling Bi-linear (allows saving Bed Leveling Data ( M500 or "LCD Menu" Store settings and restore using M420 S1 in startup G-Code )
Baby-stepping ( allows for quick adjustments to Z-Offset height adjustment during brim if needed )
Individual Axis Home Menu
Your setting seem to be the same as mine.
Link to my working Marlin_Blue.zip this is Marlin 1.1.5 here
Compare My Settings to Yours Configuration.h, Configuration_adv.h and Pins_RAMPS.h
Re: Z axis Homing Issue November 10, 2017 12:26PM |
Re: Z axis Homing Issue November 10, 2017 05:39PM |
Re: Z axis Homing Issue November 10, 2017 05:48PM |
Re: Z axis Homing Issue November 10, 2017 06:11PM |
Re: Z axis Homing Issue November 10, 2017 06:49PM |
Re: Z axis Homing Issue April 07, 2018 01:45AM |
Re: Z axis Homing Issue June 02, 2021 10:00AM |
