Travel very slow
Posted by Eddie4
Travel very slow
December 23, 2017 08:25AM
Am running Marlin (2 weeks old git clone) on a minitronics board. But every time the head needs to travel and not print on the x&y axis it does this with 0.1mm/s (guess). Am really puzzled by this behavior as when it's printing there is no problem.
My edit's in the config are as follows:
#define MOTHERBOARD BOARD_MINITRONICS
#define TEMP_SENSOR_BED 1
#define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define DEFAULT_AXIS_STEPS_PER_UNIT { 800, 160, 8000, 1666 }
#define DEFAULT_MAX_FEEDRATE { 300, 300, 2, 500 }
The rest is default.
Sliced in cura which has
print 30mm/s
travel 120mm/s
printed by octopi (same issue in cura and pronterface)
Error in terminal:
Recv: echo:busy: processing
Recv: T:199.97 /200.00 B:40.20 /40.00 @:38 [email protected]:0
Recv: T:200.00 /200.00 B:40.44 /40.00 @:37 [email protected]:0
Recv: T:200.31 /200.00 B:40.15 /40.00 @:29 [email protected]:0
Recv: T:200.31 /200.00 B:39.88 /40.00 @:30 [email protected]:0
EDIT2:
I forgot to mention all the stuff i have tried:
  • Check voltage drivers
  • Check temps drivers
  • Added custom heatsinks (just to be sure)
  • Clean clone
  • Clean flash
  • Disable thermal runaway check
  • Temps are stable
Edited 2 time(s). Last edit at 12/23/2017 08:32AM by Eddie4.
Re: Travel very slow
December 23, 2017 03:49PM
So i took a step back and it hit me: Maybe it's actually that it's to fast and the motor/driver can't handle it.
Ill report back tomorrow
December 23, 2017 06:42PM
Why the different values for X and Y steps/mm.
What micro stepping are your motor drivers set to ?
December 23, 2017 07:08PM
the numbers are also very high, a poor 8 bit ardunio is going to struggle, especially on long moves.
December 24, 2017 07:58AM
Eddie4
Well this seems to have fixed the problem but as written by obewan & dust source might using 1/32 stepping.
obewan
Am using a threaded rod for X and pully's for Y. Made this change because i wasn't happy with the quallity
I believe am running 1/32 stepping. I had to double all 1/16 values to get the mm/steps to line up.
Dust
Hmm perhaps i should look into dropping from 1/32 stepping to 1/16.
December 24, 2017 08:30PM
I would try 1/4 stepping on X ie 100 steps/mm much more reasonable for a arduino
