Z-Probe Offset Question May 07, 2018 08:47PM |
Re: Z-Probe Offset Question May 08, 2018 12:03AM |
Re: Z-Probe Offset Question May 08, 2018 06:21AM |
Re: Z-Probe Offset Question May 09, 2018 05:37PM |
Roxy
For an inductive probe, the Z_PROBE_OFFSET_FROM_EXTRUDER number will be positive. It says when the nozzle is at .35mm, the probe will trigger. The nozzle will need to be lowered by .35mm to just touch the bed.
Re: Z-Probe Offset Question May 09, 2018 05:40PM |
nkuck
I am running an inductance probe and it it positioned slightly closer to the bed than the nozzle.
Re: Z-Probe Offset Question May 09, 2018 05:41PM |
Re: Z-Probe Offset Question May 09, 2018 05:43PM |
Re: Z-Probe Offset Question May 09, 2018 06:14PM |
Re: Z-Probe Offset Question May 09, 2018 11:59PM |
Re: Z-Probe Offset Question May 10, 2018 10:35AM |
Roxy
I'm not a big fan of inductive (or capacitive) probes. They are too hard to get working right.
Re: Z-Probe Offset Question May 10, 2018 05:32PM |
Re: Z-Probe Offset Question May 10, 2018 11:34PM |
MMcLure
If you're using the 6V-36V or PNP probes you need to worry more about setup and play around with voltage dividers, diodes or optoisolators.
Re: Z-Probe Offset Question May 11, 2018 06:47AM |
