Hi there,
Hardware: Tronxy P802EA with MKS Gen 1.4 board
Firmware: Marin (1.1.x.zip … 1.1.8)
I'm trying to work out what is wrong with the auto levelling feature G29.
All of XYZ axis are moving in the right direction, calibrated ect
Homing G28 works well
Currently don't have a LCD screen setup because the "LCD 2004 5 button" display does not work with MKS Gen 1.4 from what i have researched, i think. Using Repetier-Server to manage the movements/commands
Link to a Video I recorded of what the G28 does on the printer
youtu.be]
Also, is there a way to do Bed Leveling Test through G Code? Because i am unable to test this command below through the LCD display. It doesn't seem to work when I actually print something it stays at z=0 heigh (which is ~5mm from the hot bed)
define Z_PROBE_OFFSET_FROM_EXTRUDER -3
Attached is my current Configuration.h & Configuration_adv.h
Is there something i have missed or not configured properly? Or is this a bug and should I go to a different version of Marlin?
Thanks in advanced
