Can't set Z probe offset
July 26, 2018 05:42AM
I have a Delta printer.
I've just upgraded it with Hiwin and new carbon rods.
I can't set the proper nozzle height and so the printer goes too close to the bed and don't extrude.
  • I have a nozzle based probe
  • i have optic endstop
  • This system always worked with this setup
  • I upgraded marlin fw and back then i have this problem
  • I tried + or - 0.4mm and even 1mm buth nothing changes
Here are some pics:
The actual FW:
//============================= Z Probe Options =============================
// @section probes
// See [marlinfw.org]
 * Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
 * Enable this option for a probe connected to the Z Min endstop pin.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
 * Z_MIN_PROBE_ENDSTOP
 * Enable this option for a probe connected to any pin except Z-Min.
 * (By default Marlin assumes the Z-Max endstop pin.)
 * To use a custom Z Probe pin, set Z_MIN_PROBE_PIN below.
 *  - The simplest option is to use a free endstop connector.
 *  - Use 5V for powered (usually inductive) sensors.
 *  - RAMPS 1.3/1.4 boards may use the 5V, GND, and Aux4->D32 pin:
 *    - For simple switches connect...
 *      - normally-closed switches to GND and D32.
 *      - normally-open switches to 5V and D32.
 * WARNING: Setting the wrong pin may have unexpected and potentially
 * disastrous consequences. Use with caution and do your homework.
//#define Z_MIN_PROBE_ENDSTOP
 * Probe Type
 * Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
 * Activate one of these to use Auto Bed Leveling below.
 * The "Manual Probe" provides a means to do "Auto" Bed Leveling without a probe.
 * Use G29 repeatedly, adjusting the Z height at each point with movement commands
 * or (with LCD_BED_LEVELING) the LCD controller.
//#define PROBE_MANUALLY
 * A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
 *   (e.g., an inductive probe or a nozzle-based probe-switch.)
#define FIX_MOUNTED_PROBE
 * Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_ENDSTOP_SERVO_NR 0   // Defaults to SERVO 0 connector.
//#define Z_SERVO_ANGLES {70,0}  // Z Servo Deploy and Stow angles
 * The BLTouch probe uses a Hall effect sensor and emulates a servo.
//#define BLTOUCH
#if ENABLED(BLTOUCH)
  //#define BLTOUCH_DELAY 375   // (ms) Enable and increase if needed
#endif
 * Enable one or more of the following if probing seems unreliable.
 * Heaters and/or fans can be disabled during probing to minimize electrical
 * noise. A delay can also be added to allow noise and vibration to settle.
 * These options are most useful for the BLTouch probe, but may also improve
 * readings with inductive probes and piezo sensors.
//#define PROBING_HEATERS_OFF       // Turn heaters off when probing
//#define PROBING_FANS_OFF          // Turn fans off when probing
//#define DELAY_BEFORE_PROBING 200  // (ms) To prevent vibrations from triggering piezo sensors
// A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
//#define SOLENOID_PROBE
// A sled-mounted probe like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5  // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// For Z_PROBE_ALLEN_KEY see the Delta example configurations.
 *   Z Probe to nozzle (X,Y) offset, relative to (0, 0).
 *   X and Y offsets must be integers.
 *   In the following example the X and Y offsets are both positive:
 *   #define X_PROBE_OFFSET_FROM_EXTRUDER 10
 *   #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
 *      +-- BACK ---+
 *    L |    (+) P  | R <-- probe (20,20)
 *    E |           | I
 *    F | (-) N (+) | G <-- nozzle (10,10)
 *    T |           | H
 *      |    (-)    | T
 *      O-- FRONT --+
 *    (0,0)
#define X_PROBE_OFFSET_FROM_EXTRUDER 0     // X offset: -left  +right  [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0   // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER 1.34  // Z offset: -below +above  [the nozzle]
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 5000
// Speed for the first approach when double-probing (MULTIPLE_PROBING == 2)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Speed for the "accurate" probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 10)
// The number of probes to perform at each point.
//   Set to 2 for a fast/slow probe, using the second probe result.
//   Set to 3 or more for slow probes, averaging the results.
//#define MULTIPLE_PROBING 2
 * Allen key retractable z-probe as seen on many Kossel delta printers - [reprap.org]
 * Deploys by touching z-axis belt. Retracts by pushing the probe down. Uses Z_MIN_PIN.
//#define Z_PROBE_ALLEN_KEY
#if ENABLED(Z_PROBE_ALLEN_KEY)
  // 2 or 3 sets of coordinates for deploying and retracting the spring loaded touch probe on G29,
  // if servo actuated touch probe is not defined. Uncomment as appropriate for your printer/probe.
  #define Z_PROBE_ALLEN_KEY_DEPLOY_1_X 30.0
  #define Z_PROBE_ALLEN_KEY_DEPLOY_1_Y DELTA_PRINTABLE_RADIUS
  #define Z_PROBE_ALLEN_KEY_DEPLOY_1_Z 100.0
  #define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_PROBE_SPEED
  #define Z_PROBE_ALLEN_KEY_DEPLOY_2_X 0.0
  #define Z_PROBE_ALLEN_KEY_DEPLOY_2_Y DELTA_PRINTABLE_RADIUS
  #define Z_PROBE_ALLEN_KEY_DEPLOY_2_Z 100.0
  #define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_PROBE_SPEED)/10
  #define Z_PROBE_ALLEN_KEY_DEPLOY_3_X Z_PROBE_ALLEN_KEY_DEPLOY_2_X * 0.75
  #define Z_PROBE_ALLEN_KEY_DEPLOY_3_Y Z_PROBE_ALLEN_KEY_DEPLOY_2_Y * 0.75
  #define Z_PROBE_ALLEN_KEY_DEPLOY_3_Z Z_PROBE_ALLEN_KEY_DEPLOY_2_Z
  #define Z_PROBE_ALLEN_KEY_DEPLOY_3_FEEDRATE XY_PROBE_SPEED
  #define Z_PROBE_ALLEN_KEY_STOW_1_X -64.0 // Move the probe into position
  #define Z_PROBE_ALLEN_KEY_STOW_1_Y 56.0
  #define Z_PROBE_ALLEN_KEY_STOW_1_Z 23.0
  #define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_PROBE_SPEED
  #define Z_PROBE_ALLEN_KEY_STOW_2_X -64.0 // Push it down
  #define Z_PROBE_ALLEN_KEY_STOW_2_Y 56.0
  #define Z_PROBE_ALLEN_KEY_STOW_2_Z 3.0
  #define Z_PROBE_ALLEN_KEY_STOW_2_FEEDRATE (XY_PROBE_SPEED)/10
  #define Z_PROBE_ALLEN_KEY_STOW_3_X -64.0 // Move it up to clear
  #define Z_PROBE_ALLEN_KEY_STOW_3_Y 56.0
  #define Z_PROBE_ALLEN_KEY_STOW_3_Z 50.0
  #define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE XY_PROBE_SPEED
  #define Z_PROBE_ALLEN_KEY_STOW_4_X 0.0
  #define Z_PROBE_ALLEN_KEY_STOW_4_Y 0.0
  #define Z_PROBE_ALLEN_KEY_STOW_4_Z Z_PROBE_ALLEN_KEY_STOW_3_Z
  #define Z_PROBE_ALLEN_KEY_STOW_4_FEEDRATE XY_PROBE_SPEED
#endif // Z_PROBE_ALLEN_KEY
 * Z probes require clearance when deploying, stowing, and moving between
 * probe points to avoid hitting the bed and other hardware.
 * Servo-mounted probes require extra space for the arm to rotate.
 * Inductive probes need space to keep from triggering early.
 * Use these settings to specify the distance (mm) to raise the probe (or
 * lower the bed). The values set here apply over and above any (negative)
 * probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
 * Only integer values >= 1 are valid here.
 * Example: `M851 Z-5` with a CLEARANCE of 4  =>  9mm from bed to nozzle.
 *     But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE   15 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES  3 // Z Clearance between probe points
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// Enable the M48 repeatability test to test probe accuracy
//#define Z_MIN_PROBE_REPEATABILITY_TEST
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
// @section extruder
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled.
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR true // DELTA does not invert
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
// Enable this option for Toshiba stepper drivers
//#define CONFIG_STEPPERS_TOSHIBA
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR true
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
// @section homing
//#define NO_MOTION_BEFORE_HOMING  // Inhibit movement until all axes have been homed
//#define Z_HOMING_HEIGHT 4  // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
                             // Be sure you have this distance over your Z_MAX_POS in case.
// Direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR 1  // deltas always home to max
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
// @section machine
// The size of the print bed
#define X_BED_SIZE ((DELTA_PRINTABLE_RADIUS) * 2)
#define Y_BED_SIZE ((DELTA_PRINTABLE_RADIUS) * 2)
// Travel limits (mm) after homing, corresponding to endstop positions.
#define X_MIN_POS -(DELTA_PRINTABLE_RADIUS)
#define Y_MIN_POS -(DELTA_PRINTABLE_RADIUS)
#define Z_MIN_POS 0
#define X_MAX_POS DELTA_PRINTABLE_RADIUS
#define Y_MAX_POS DELTA_PRINTABLE_RADIUS
#define Z_MAX_POS MANUAL_Z_HOME_POS
 * Software Endstops
 * - Prevent moves outside the set machine bounds.
 * - Individual axes can be disabled, if desired.
 * - X and Y only apply to Cartesian robots.
 * - Use 'M211' to set software endstops on/off or report current state
// Min software endstops curtail movement below minimum coordinate bounds
#define MIN_SOFTWARE_ENDSTOPS
#if ENABLED(MIN_SOFTWARE_ENDSTOPS)
  #define MIN_SOFTWARE_ENDSTOP_X
  #define MIN_SOFTWARE_ENDSTOP_Y
  #define MIN_SOFTWARE_ENDSTOP_Z
#endif
// Max software endstops curtail movement above maximum coordinate bounds
#define MAX_SOFTWARE_ENDSTOPS
#if ENABLED(MAX_SOFTWARE_ENDSTOPS)
  #define MAX_SOFTWARE_ENDSTOP_X
  #define MAX_SOFTWARE_ENDSTOP_Y
  #define MAX_SOFTWARE_ENDSTOP_Z
#endif
 * Filament Runout Sensor
 * A mechanical or opto endstop is used to check for the presence of filament.
 * RAMPS-based boards use SERVO3_PIN.
 * For other boards you may need to define FIL_RUNOUT_PIN.
 * By default the firmware assumes HIGH = has filament, LOW = ran out
//#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
  #define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
  #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
  #define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
//=============================== Bed Leveling ==============================
// @section calibrate
 * Choose one of the options below to enable G29 Bed Leveling. The parameters
 * and behavior of G29 will change depending on your selection.
 *  If using a Probe for Z Homing, enable Z_SAFE_HOMING also!
 * - AUTO_BED_LEVELING_3POINT
 *   Probe 3 arbitrary points on the bed (that aren't collinear)
 *   You specify the XY coordinates of all 3 points.
 *   The result is a single tilted plane. Best for a flat bed.
 * - AUTO_BED_LEVELING_LINEAR
 *   Probe several points in a grid.
 *   You specify the rectangle and the density of sample points.
 * - AUTO_BED_LEVELING_BILINEAR
 *   The result is a mesh, best for large or uneven beds.
 * - AUTO_BED_LEVELING_UBL (Unified Bed Leveling)
 *   A comprehensive bed leveling system combining the features and benefits
 *   of other systems. UBL also includes integrated Mesh Generation, Mesh
 *   Validation and Mesh Editing systems.
 * - MESH_BED_LEVELING
 *   Probe a grid manually
 *   The result is a mesh, suitable for large or uneven beds. (See BILINEAR.)
 *   For machines without a probe, Mesh Bed Leveling provides a method to perform
 *   leveling in steps so you can manually adjust the Z height at each grid-point.
 *   With an LCD controller the process is guided step-by-step.
//#define AUTO_BED_LEVELING_3POINT
#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
//#define AUTO_BED_LEVELING_UBL
//#define MESH_BED_LEVELING
 * Enable detailed logging of G28, G29, M48, etc.
 * Turn on with the command 'M111 S32'.
 * NOTE: Requires a lot of PROGMEM!
//#define DEBUG_LEVELING_FEATURE
#if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_BILINEAR) || ENABLED(AUTO_BED_LEVELING_UBL)
  // Gradually reduce leveling correction until a set height is reached,
  // at which point movement will be level to the machine's XY plane.
  // The height can be set with M420 Z
  //#define ENABLE_LEVELING_FADE_HEIGHT
  // Set the boundaries for probing (where the probe can reach).
  #define DELTA_PROBEABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 10)
  // For Cartesian machines, instead of dividing moves on mesh boundaries,
  // split up moves into short segments like a Delta. This follows the
  // contours of the bed more closely than edge-to-edge straight moves.
  #define SEGMENT_LEVELED_MOVES
  #define LEVELED_SEGMENT_LENGTH 5.0 // (mm) Length of all segments (except the last one)
   * Enable the G26 Mesh Validation Pattern tool.
  //#define G26_MESH_VALIDATION   // Enable G26 mesh validation
  #if ENABLED(G26_MESH_VALIDATION)
    #define MESH_TEST_NOZZLE_SIZE     0.4   // (mm) Diameter of primary nozzle.
    #define MESH_TEST_LAYER_HEIGHT    0.2   // (mm) Default layer height for the G26 Mesh Validation Tool.
    #define MESH_TEST_HOTEND_TEMP   205.0   // (°C) Default nozzle temperature for the G26 Mesh Validation Tool.
    #define MESH_TEST_BED_TEMP       60.0   // (°C) Default bed temperature for the G26 Mesh Validation Tool.
  #endif
#endif
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
  // Set the number of grid points per dimension.
  // Works best with 5 or more points in each dimension.
  #define GRID_MAX_POINTS_X 9
  #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
  #define LEFT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS)
  #define RIGHT_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS
  #define FRONT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS)
  #define BACK_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS
  // The Z probe minimum outer margin (to validate G29 parameters).
  #define MIN_PROBE_EDGE 10
  // Probe along the Y axis, advancing X after each column
  //#define PROBE_Y_FIRST
  #if ENABLED(AUTO_BED_LEVELING_BILINEAR)
    // Beyond the probed grid, continue the implied tilt?
    // Default is to maintain the height of the nearest edge.
    //#define EXTRAPOLATE_BEYOND_GRID
    // Experimental Subdivision of the grid by Catmull-Rom method.
    // Synthesizes intermediate points to produce a more detailed mesh.
    //#define ABL_BILINEAR_SUBDIVISION
    #if ENABLED(ABL_BILINEAR_SUBDIVISION)
      // Number of subdivisions between probe points
      #define BILINEAR_SUBDIVISIONS 3
    #endif
  #endif
#elif ENABLED(AUTO_BED_LEVELING_3POINT)
  // 3 arbitrary points to probe.
  // A simple cross-product is used to estimate the plane of the bed.
  #define ABL_PROBE_PT_1_X 15
  #define ABL_PROBE_PT_1_Y 180
  #define ABL_PROBE_PT_2_X 15
  #define ABL_PROBE_PT_2_Y 20
  #define ABL_PROBE_PT_3_X 170
  #define ABL_PROBE_PT_3_Y 20
#elif ENABLED(AUTO_BED_LEVELING_UBL)
Re: Can't set Z probe offset
July 26, 2018 12:01PM
I updated the firmware to the bugfix version but it is always 0.5mm too close to the bed no matter the value I set on Z_PROBE_OFFSET
July 27, 2018 06:18AM
Are you changing the Z offset in the config.h or in the eeprom.
Values in eeprom will always have precedence over the values in config
In the latter case where you update the config.h and upload the firware, you need to send a M502 followed by M500 to update the eeprom values.
