Hi guys, using Marlin 1.1.0-RC7 firmware with Z-probe, as all working fine from beginning I notice that points where my probe doing autolevel is not where I want to. I would like to change them. Not sure where should I look in my firmware.
I've found this section, my probe checking 9 points not sure if I looking in right part of the code
Configuration.h
#define AUTO_BED_LEVELING_GRID
#if ENABLED(AUTO_BED_LEVELING_GRID)
#define LEFT_PROBE_BED_POSITION 40
#define RIGHT_PROBE_BED_POSITION 200
#define FRONT_PROBE_BED_POSITION 5
#define BACK_PROBE_BED_POSITION 140
#define MIN_PROBE_EDGE 10 // The Z probe minimum square sides can be no smaller than this.
// Set the number of grid points per dimension.
// You probably don't need more than 3 (squared=9).
#define AUTO_BED_LEVELING_GRID_POINTS 3
#else // !AUTO_BED_LEVELING_GRID
// Arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 60
#define ABL_PROBE_PT_1_Y 10
#define ABL_PROBE_PT_2_X 107
#define ABL_PROBE_PT_2_Y 140
#define ABL_PROBE_PT_3_X 163
#define ABL_PROBE_PT_3_Y 20
regards
Edited 1 time(s). Last edit at 10/23/2018 06:36PM by karcio.
karcio
