Marlin firmware V 1.1.8 / 1.1.9, RAMPS 1.4 board Configuration "EFB"
I'm also using a board known as an RRD Fan extender board.
This board plugs into the Servo port and uses pin 6 and 11.
From what I understand there are 3 fan definitions possible.
FAN_PIN seem to be used to define the D9 Pin.
While FAN1_PIN AND FAN2_PIN go undefined.
So in the "pins_RAMPS.h" file I configured the following: in V1.1.9
#if ENABLED(IS_RAMPS_EF
// Hotend, Fan, Bed
#define HEATER_BED_PIN RAMPS_D8_PIN
#define FAN1_PIN 6 // DJB
#define FAN2_PIN 11
In V 1.1.8
// Hotend, Fan, Bed
#define FAN_PIN RAMPS_D9_PIN
#define FAN1_PIN 6 // Define servo pins for fan use DJB
#define FAN2_PIN 11
In both cases FAN1_Pin works by using the M106 P1 S128 command.
But in the case of FAN2_Pin it does not work.
Using M106 P2 S128 or M42 P11 S128 does not work.
So I figure I am either misinformed about FAN2_PIN, it uses a different
command structure or I may have a bad board.
Any help would be appreciated.
thank you
