Hi everybody,
So I am working on a convoyer type XY core 3D printer that uses a Kapton covered belt ( Board: MKS Gen 1.4 based on ATmega 2560) . I need a way to modify the firmware in order to make it possible to print all the G-Codes loaded into the SD card. In other words, after finishing the read and execute process of a file (G-Code), it automatically goes to the next file and does the same until all the files are already been processed.
Thank you.
