I'm a bit confused and also Lazy LOL so rather than messing around with settings, I was hoping someone smarter than myself could explain.
Marlin has the provision to set these things individually for each axis but when G-Code is generated for a file these is just 1 Feed Rate that the entire system is commanded to run at. Am I correct so far?
So, if that is the case and you have drastically different settings in the firmware for different the different axis (i.e. I have to set the acceleration for my Y Axis much lower because it is moving so much weight it will rattle my machine apart if I do not). How is this interpreted when my controller is spitting out commands to my motors?
Are we limited by the on axis that has the lowest Max Feedrate?
It's great to have so many option to control speed but, I feel like I could optimize my machine's performance is I understood this better.
Many thanks in advance for anyone who can offer up some insight!
