Firmware allows you to set a Max Feed Rate for each axis. When Printing there is typically a user change-able feed rate setting.Typically allowing the user to go +/- 100%. If a Print feed rate setting of 150% is selected and you have already config your slicer software to print at the max feed rate you set in FW- How does Marlin interpolate this?
The obvious answer (I Think) is you cannot print faster than you set in FW. But what happens when 1 axis is maxed out but the others still have headroom? What is the ultimate speed limitation?
Thanks for any replies!
