C++ coding help with Marlin please April 24, 2019 07:50PM |
void Endstops::report_state() { if (endstop_hit_bits) { #if ENABLED(ULTRA_LCD) char chrX = ' ', chrY = ' ', chrZ = ' ', chrP = ' '; #define _SET_STOP_CHAR(A,C) (chr## A = C) #else #define _SET_STOP_CHAR(A,C) ; #endif #define _ENDSTOP_HIT_ECHO(A,C) do{ \ SERIAL_ECHOPAIR(" " STRINGIFY(A) ":", stepper.triggered_position_mm(A ##_AXIS)); \ _SET_STOP_CHAR(A,C); }while(0) #define _ENDSTOP_HIT_TEST(A,C) \ if (TEST(endstop_hit_bits, A ##_MIN) || TEST(endstop_hit_bits, A ##_MAX)) \ _ENDSTOP_HIT_ECHO(A,C) #define ENDSTOP_HIT_TEST_) _ENDSTOP_HIT_TEST(X,'X') #define ENDSTOP_HIT_TEST_Y() _ENDSTOP_HIT_TEST(Y,'Y') #define ENDSTOP_HIT_TEST_Z() _ENDSTOP_HIT_TEST(Z,'Z') #define ENDSTOP_HIT_TEST_E() _ENDSTOP_HIT_TEST(E,'E') SERIAL_ECHO_START(); SERIAL_ECHOPGM(MSG_ENDSTOPS_HIT); ENDSTOP_HIT_TEST_); ENDSTOP_HIT_TEST_Y(); ENDSTOP_HIT_TEST_Z(); ENDSTOP_HIT_TEST_E(); #if ENABLED(Z_MIN_PROBE_ENDSTOP) #define P_AXIS Z_AXIS if (TEST(endstop_hit_bits, Z_MIN_PROBE)) _ENDSTOP_HIT_ECHO(P, 'P'); #endif SERIAL_EOL(); #if ENABLED(ULTRA_LCD) lcd_status_printf_P(0, PSTR(MSG_LCD_ENDSTOPS " %c %c %c %c"), chrX, chrY, chrZ, chrP); #endif hit_on_purpose(); #if ENABLED(ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED) && ENABLED(SDSUPPORT) if (stepper.abort_on_endstop_hit) { card.sdprinting = false; card.closefile(); quickstop_stepper(); thermalManager.disable_all_heaters(); // switch off all heaters. } #endif } } // Endstops::report_state
Re: C++ coding help with Marlin please April 24, 2019 08:39PM |
Admin Registered: 13 years ago Posts: 7,005 |
enum EndstopEnum : char { X_MIN, Y_MIN, Z_MIN, Z_MIN_PROBE, X_MAX, Y_MAX, Z_MAX, X2_MIN, X2_MAX, Y2_MIN, Y2_MAX, Z2_MIN, Z2_MAX, E_MIN, E_MAX };
Re: C++ coding help with Marlin please April 24, 2019 08:51PM |
