Z- Probing G28 works but G29 gives Probing failed May 08, 2019 04:41PM |
Re: Z- Probing G28 works but G29 gives Probing failed May 09, 2019 02:27PM |
echoEBUG:LEVELING ok current_position=(102.00, 42.00, -0.70) : >>> G29 Machine Type: Core Probe: FIX_MOUNTED_PROBE Probe Offset X:5 Y:65 Z:-1.30 (Right-Back & Below Nozzle) Auto Bed Leveling: LINEAR (disabled) current_position=(102.00, 42.00, -0.70) : set_probe_deployed deploy: 1 do_probe_raise(10.00) >>> do_blocking_move_to(102.00, 42.00, 11.30) <<< do_blocking_move_to echo:busy: processing >>> do_blocking_move_to(102.00, 42.00, 11.30) <<< do_blocking_move_to >>> probe_pt(75.00, 75.00, raise, 0, probe_relative) current_position=(102.00, 42.00, 11.30) : >>> do_blocking_move_to(70.00, 10.00, 11.30) <<< do_blocking_move_to current_position=(70.00, 10.00, 11.30) : set_probe_deployed deploy: 1 current_position=(70.00, 10.00, 11.30) : >>> run_z_probe current_position=(70.00, 10.00, 11.30) : >>> do_probe_move >>> do_blocking_move_to(70.00, 10.00, -0.70) <<< do_blocking_move_to echo:busy: processing echo:busy: processing echo:busy: processing current_position=(70.00, 10.00, 0.39) : sync_plan_position current_position=(70.00, 10.00, 0.39) : <<< do_probe_move current_position=(70.00, 10.00, 0.39) : <<< run_z_probe >>> do_blocking_move_to(70.00, 10.00, 5.39) <<< do_blocking_move_to echo:busy: processing <<< probe_pt >>> probe_pt(104.00, 75.00, raise, 0, probe_relative) current_position=(70.00, 10.00, 5.39) : >>> do_blocking_move_to(99.00, 10.00, 5.39) <<< do_blocking_move_to current_position=(99.00, 10.00, 5.39) : set_probe_deployed deploy: 1 current_position=(99.00, 10.00, 5.39) : >>> run_z_probe current_position=(99.00, 10.00, 5.39) : >>> do_probe_move >>> do_blocking_move_to(99.00, 10.00, -0.70) <<< do_blocking_move_to echo:busy: processing current_position=(99.00, 10.00, 0.40) : sync_plan_position current_position=(99.00, 10.00, 0.40) : <<< do_probe_move current_position=(99.00, 10.00, 0.40) : <<< run_z_probe >>> do_blocking_move_to(99.00, 10.00, 5.40) <<< do_blocking_move_to echo:busy: processing <<< probe_pt >>> probe_pt(133.00, 75.00, raise, 0, probe_relative) current_position=(99.00, 10.00, 5.40) : >>> do_blocking_move_to(128.00, 10.00, 5.40) <<< do_blocking_move_to current_position=(128.00, 10.00, 5.40) : set_probe_deployed deploy: 1 current_position=(128.00, 10.00, 5.40) : >>> run_z_probe current_position=(128.00, 10.00, 5.40) : >>> do_probe_move >>> do_blocking_move_to(128.00, 10.00, -0.70) <<< do_blocking_move_to echo:busy: processing echo:busy: processing current_position=(128.00, 10.00, 0.50) : sync_plan_position current_position=(128.00, 10.00, 0.50) : <<< do_probe_move current_position=(128.00, 10.00, 0.50) : <<< run_z_probe >>> do_blocking_move_to(128.00, 10.00, 5.50) <<< do_blocking_move_to <<< probe_pt >>> probe_pt(133.00, 104.00, raise, 0, probe_relative) current_position=(128.00, 10.00, 5.50) : >>> do_blocking_move_to(128.00, 39.00, 5.50) <<< do_blocking_move_to current_position=(128.00, 39.00, 5.50) : set_probe_deployed deploy: 1 current_position=(128.00, 39.00, 5.50) : >>> run_z_probe current_position=(128.00, 39.00, 5.50) : >>> do_probe_move >>> do_blocking_move_to(128.00, 39.00, -0.70) <<< do_blocking_move_to echo:busy: processing echo:busy: processing current_position=(128.00, 39.00, -0.50) : sync_plan_position current_position=(128.00, 39.00, -0.50) : <<< do_probe_move current_position=(128.00, 39.00, -0.50) : <<< run_z_probe >>> do_blocking_move_to(128.00, 39.00, 4.50) <<< do_blocking_move_to echo:busy: processing <<< probe_pt >>> probe_pt(104.00, 104.00, raise, 0, probe_relative) current_position=(128.00, 39.00, 4.50) : >>> do_blocking_move_to(99.00, 39.00, 4.50) <<< do_blocking_move_to current_position=(99.00, 39.00, 4.50) : set_probe_deployed deploy: 1 current_position=(99.00, 39.00, 4.50) : >>> run_z_probe current_position=(99.00, 39.00, 4.50) : >>> do_probe_move >>> do_blocking_move_to(99.00, 39.00, -0.70) <<< do_blocking_move_to echo:busy: processing current_position=(99.00, 39.00, -0.60) : sync_plan_position current_position=(99.00, 39.00, -0.60) : <<< do_probe_move current_position=(99.00, 39.00, -0.60) : <<< run_z_probe >>> do_blocking_move_to(99.00, 39.00, 4.40) <<< do_blocking_move_to echo:busy: processing <<< probe_pt >>> probe_pt(75.00, 104.00, raise, 0, probe_relative) current_position=(99.00, 39.00, 4.40) : >>> do_blocking_move_to(70.00, 39.00, 4.40) <<< do_blocking_move_to current_position=(70.00, 39.00, 4.40) : set_probe_deployed deploy: 1 current_position=(70.00, 39.00, 4.40) : >>> run_z_probe current_position=(70.00, 39.00, 4.40) : >>> do_probe_move >>> do_blocking_move_to(70.00, 39.00, -0.70) <<< do_blocking_move_to echo:busy: processing echo:busy: processing current_position=(70.00, 39.00, -0.69) : sync_plan_position current_position=(70.00, 39.00, -0.69) : <<< do_probe_move current_position=(70.00, 39.00, -0.69) : <<< run_z_probe >>> do_blocking_move_to(70.00, 39.00, 4.31) <<< do_blocking_move_to <<< probe_pt >>> probe_pt(75.00, 133.00, raise, 0, probe_relative) current_position=(70.00, 39.00, 4.31) : >>> do_blocking_move_to(70.00, 68.00, 4.31) <<< do_blocking_move_to current_position=(70.00, 68.00, 4.31) : set_probe_deployed deploy: 1 current_position=(70.00, 68.00, 4.31) : >>> run_z_probe current_position=(70.00, 68.00, 4.31) : >>> do_probe_move >>> do_blocking_move_to(70.00, 68.00, -0.70) <<< do_blocking_move_to echo:busy: processing echo:busy: processing current_position=(70.00, 68.00, -0.70) : sync_plan_position current_position=(70.00, 68.00, -0.70) : <<< do_probe_move SLOW Probe fail! current_position=(70.00, 68.00, -0.70) : <<< run_z_probe >>> do_blocking_move_to(70.00, 68.00, 4.30) <<< do_blocking_move_to current_position=(70.00, 68.00, 4.30) : set_probe_deployed deploy: 0 >>> do_blocking_move_to(70.00, 68.00, 4.30) <<< do_blocking_move_to Errorrobing failed <<< probe_pt current_position=(70.00, 68.00, 4.30) : set_probe_deployed deploy: 0 current_position=(70.00, 68.00, 4.30) : > probing complete <<< G29 X:70.00 Y:68.00 Z:4.30 E:0.00 Count A:11040 B:160 Z:11008 ok
Re: Z- Probing G28 works but G29 gives Probing failed May 10, 2019 07:36AM |
Re: Z- Probing G28 works but G29 gives Probing failed May 11, 2019 01:50AM |
Re: Z- Probing G28 works but G29 gives Probing failed May 11, 2019 03:16AM |
Re: Z- Probing G28 works but G29 gives Probing failed May 11, 2019 03:21PM |
G29 Machine Type: Cartesian Probe: FIX_MOUNTED_PROBE Probe Offset X:20 Y:0 Z:-2.75 (Right-Center & Below Nozzle) Auto Bed Leveling: BILINEAR (disabled) current_position=(155.00, 25.00, 5.75) : set_probe_deployed deploy: 1 do_probe_raise(5.00) >>> do_blocking_move_to(155.00, 25.00, 7.75) <<< do_blocking_move_to >>> do_blocking_move_to(155.00, 25.00, 7.75) <<< do_blocking_move_to current_position=(155.00, 25.00, 7.75) : setup_for_endstop_or_probe_move >>> probe_pt(25.00, 25.00, raise, 0, probe_relative) current_position=(155.00, 25.00, 7.75) : >>> do_blocking_move_to(5.00, 25.00, 7.75) echo:busy: processing <<< do_blocking_move_to current_position=(5.00, 25.00, 7.75) : set_probe_deployed deploy: 1 current_position=(5.00, 25.00, 7.75) : >>> run_z_probe current_position=(5.00, 25.00, 7.75) : >>> do_probe_move >>> do_blocking_move_to(5.00, 25.00, 0.75) echo:busy: processing <<< do_blocking_move_to current_position=(5.00, 25.00, 2.06) : sync_plan_position current_position=(5.00, 25.00, 2.06) : <<< do_probe_move current_position=(5.00, 25.00, 2.06) : <<< run_z_probe >>> do_blocking_move_to(5.00, 25.00, 7.06) echo:busy: processing echo:busy: processing <<< do_blocking_move_to <<< probe_pt >>> probe_pt(100.00, 25.00, raise, 0, probe_relative) current_position=(5.00, 25.00, 7.06) : >>> do_blocking_move_to(80.00, 25.00, 7.06) <<< do_blocking_move_to current_position=(80.00, 25.00, 7.06) : set_probe_deployed deploy: 1 current_position=(80.00, 25.00, 7.06) : >>> run_z_probe current_position=(80.00, 25.00, 7.06) : >>> do_probe_move >>> do_blocking_move_to(80.00, 25.00, 0.75) echo:busy: processing <<< do_blocking_move_to current_position=(80.00, 25.00, 1.37) : sync_plan_position current_position=(80.00, 25.00, 1.37) : <<< do_probe_move current_position=(80.00, 25.00, 1.37) : <<< run_z_probe >>> do_blocking_move_to(80.00, 25.00, 6.37) echo:busy: processing echo:busy: processing <<< do_blocking_move_to <<< probe_pt >>> probe_pt(175.00, 25.00, raise, 0, probe_relative) current_position=(80.00, 25.00, 6.37) : >>> do_blocking_move_to(155.00, 25.00, 6.37) <<< do_blocking_move_to current_position=(155.00, 25.00, 6.37) : set_probe_deployed deploy: 1 current_position=(155.00, 25.00, 6.37) : >>> run_z_probe current_position=(155.00, 25.00, 6.37) : >>> do_probe_move >>> do_blocking_move_to(155.00, 25.00, 0.75) echo:busy: processing echo:busy: processing <<< do_blocking_move_to current_position=(155.00, 25.00, 0.75) : sync_plan_position current_position=(155.00, 25.00, 0.75) : <<< do_probe_move SLOW Probe fail! current_position=(155.00, 25.00, 0.75) : <<< run_z_probe >>> do_blocking_move_to(155.00, 25.00, 5.75) echo:busy: processing <<< do_blocking_move_to Errorrobing failed <<< probe_pt current_position=(155.00, 25.00, 5.75) : set_probe_deployed deploy: 0 >>> do_blocking_move_to(155.00, 25.00, 5.75) <<< do_blocking_move_to current_position=(155.00, 25.00, 5.75) : > probing complete current_position=(155.00, 25.00, 5.75) : clean_up_after_endstop_or_probe_move <<< G29 X:155.00 Y:25.00 Z:5.75 E:0.00 Count X:12400 Y:2000 Z:14720 ok
Re: Z- Probing G28 works but G29 gives Probing failed May 14, 2019 06:23AM |
Re: Z- Probing G28 works but G29 gives Probing failed May 14, 2019 06:48AM |
Re: Z- Probing G28 works but G29 gives Probing failed May 14, 2019 07:57AM |
Re: Z- Probing G28 works but G29 gives Probing failed May 21, 2019 01:02PM |
Re: Z- Probing G28 works but G29 gives Probing failed May 21, 2019 06:59PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Z- Probing G28 works but G29 gives Probing failed July 29, 2019 04:23AM |
Re: Z- Probing G28 works but G29 gives Probing failed December 04, 2019 08:08PM |
