OK that was an oversight on my part, I didn't Check the code before sending it to the printer
so I added // in front of the command to disable it and reloaded it.
this is the new result
16:35:57.870 : OpenGL version:3.3.11672 Compatibility Profile Context
16:35:57.901 : OpenGL extensions:GL_AMDX_debug_output GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_sample_positions GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_texture_storage GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
16:35:57.901 : OpenGL renderer:ATI Radeon HD 3450
16:35:57.901 : Using fast VBOs for rendering is possible
16:36:07.136 : Printer reset detected - initializing
16:36:07.136 : start
16:36:07.136 : echo: External Reset
16:36:07.136 : Marlin bugfix-1.1.x
16:36:07.151 : echo: Last Updated: 2018-07-31 | Author: (1138-4EB, Geeetech Prusa i3 Pro B config)
16:36:07.151 : echo:Compiled: Oct 12 2019
16:36:07.151 : echo: Free Memory: 3698 PlannerBufferBytes: 1232
16:36:07.198 : echo:V56 stored settings retrieved (684 bytes; crc 869)
16:36:07.198 : echo: G21 ; (mm)
16:36:07.198 : echo: M149 C ; Units in Celsius
16:36:07.198 : echo:Filament settings: Disabled
16:36:07.198 : echo: M200 D1.75
16:36:07.198 : echo: M200 D0
16:36:07.198 : echo
teps per unit:
16:36:07.198 : echo: M92 X78.74 Y78.74 Z380.00 E105.00
16:36:07.198 : echo:Maximum feedrates (units/s):
16:36:07.198 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
16:36:07.198 : echo:Maximum Acceleration (units/s2):
16:36:07.198 : echo: M201 X5000 Y5000 Z75 E5000
16:36:07.198 : echo:Acceleration (units/s2): P R T
16:36:07.198 : echo: M204 P1000.00 R2000.00 T3000.00
16:36:07.198 : echo:Advanced: Q S T X Y Z E
16:36:07.198 : echo: M205 Q20000 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00
16:36:07.198 : echo:Home offset:
16:36:07.198 : echo: M206 X0.00 Y0.00 Z0.00
16:36:07.198 : echo:Auto Bed Leveling:
16:36:07.198 : echo: M420 S0 Z0.00
16:36:07.198 : echo:Material heatup parameters:
16:36:07.198 : echo: M145 S0 H200 B60 F170
16:36:07.198 : echo: M145 S1 H240 B110 F170
16:36:07.198 : echo
ID settings:
16:36:07.198 : echo: M301 P12.33 I0.51 D74.50
16:36:07.198 : echo
kew Factor:
16:36:07.198 : echo: M852 S0.003624
16:36:10.807 : FIRMWARE_NAME:Marlin bugfix-1.1.x (Github) SOURCE_CODE_URL:[
github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE
rusa i3 Pro B EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
16:36:10.807 : Cap
ERIAL_XON_XOFF:0
16:36:10.807 : Cap:EEPROM:1
16:36:10.807 : Cap:VOLUMETRIC:1
16:36:10.807 : Cap:AUTOREPORT_TEMP:1
16:36:10.807 : Cap
ROGRESS:0
16:36:10.807 : Cap
RINT_JOB:1
16:36:10.807 : Cap:AUTOLEVEL:0
16:36:10.807 : Cap:Z_PROBE:0
16:36:10.807 : Cap:LEVELING_DATA:1
16:36:10.807 : Cap:BUILD_PERCENT:0
16:36:10.807 : Cap
OFTWARE_POWER:0
16:36:10.807 : Cap:TOGGLE_LIGHTS:0
16:36:10.807 : Cap:CASE_LIGHT_BRIGHTNESS:0
16:36:10.807 : Cap:EMERGENCY_PARSER:0
16:36:10.807 : Cap:AUTOREPORT_SD_STATUS:0
16:36:10.807 : Cap:THERMAL_PROTECTION:1
16:36:10.886 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
16:36:10.886 : echo
EBUG:INFO,ERRORS
16:36:10.886 : echo:Active Extruder: 0
16:36:10.886 : Begin file list
16:36:10.886 : End file list
16:36:10.886 : echo:Unknown command: "M80"
16:36:10.901 : echo
EBUG:INFO,ERRORS
16:36:10.901 : echo:Active Extruder: 0
16:37:08.245 : echo: G21 ; (mm)
16:37:08.245 : echo: M149 C ; Units in Celsius
16:37:08.245 : echo:Filament settings: Disabled
16:37:08.245 : echo: M200 D1.75
16:37:08.245 : echo: M200 D0
16:37:08.245 : echo
teps per unit:
16:37:08.245 : echo: M92 X78.74 Y78.74 Z380.00 E105.00
16:37:08.245 : echo:Maximum feedrates (units/s):
16:37:08.245 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
16:37:08.245 : echo:Maximum Acceleration (units/s2):
16:37:08.245 : echo: M201 X5000 Y5000 Z75 E5000
16:37:08.245 : echo:Acceleration (units/s2): P R T
16:37:08.245 : echo: M204 P1000.00 R2000.00 T3000.00
16:37:08.245 : echo:Advanced: Q S T X Y Z E
16:37:08.245 : echo: M205 Q20000 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00
16:37:08.245 : echo:Home offset:
16:37:08.245 : echo: M206 X0.00 Y0.00 Z0.00
16:37:08.245 : echo:Auto Bed Leveling:
16:37:08.245 : echo: M420 S0 Z0.00
16:37:08.245 : echo:Material heatup parameters:
16:37:08.245 : echo: M145 S0 H200 B60 F170
16:37:08.245 : echo: M145 S1 H240 B110 F170
16:37:08.245 : echo
ID settings:
16:37:08.245 : echo: M301 P12.33 I0.51 D74.50
16:37:08.245 : echo
kew Factor:
16:37:08.245 : echo: M852 S0.003624
