REPRAP DISCOUNT FULL GRAPHIC SMART CONTROLLER DISPLAY ERROR
November 26, 2019 09:55PM
Hi, I recently purchased a new LCD screen, my problem arises with this has a whole line, and quite thick, pixels which do not show information, if anyone knows the solution would appreciate it.
Re: REPRAP DISCOUNT FULL GRAPHIC SMART CONTROLLER DISPLAY ERROR
November 27, 2019 05:01AM
Test with short cables.
What controller is this on?
November 27, 2019 10:11PM
I'm already using short cables, I'm using Marlin 1.1.9 with ramps.
November 27, 2019 10:32PM
Try the GLCD tester [github.com]
What are those cables, they don't look like normal ribbon cables.
November 28, 2019 03:32AM
Dust
They look wrapped in aluminium foil. Are you sure there are no shorted pins?
http://www.marinusdebeer.nl/
November 28, 2019 03:53AM
Ohmarinus
That is my guess also, which you would normally only try if you where trying to sheid overly long cables...
Which is why I said to use short cables for testing.
December 01, 2019 11:21PM
Its just problem of your display beeing to slow (lik mine), i added the ST7920_Delay setting, since that time its fine
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
#define ST7920_DELAY_1 DELAY_NS(63)
#define ST7920_DELAY_2 DELAY_NS(63)
#define ST7920_DELAY_3 DELAY_NS(63) // this is the defaults for a 16mhz processor (ie a mega2560)
December 05, 2019 10:34PM
Works perfectly. Thanks.
