geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 01, 2020 12:47PM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 01, 2020 02:15PM |
// define digital pin 4 for the filament runout sensor. Use the RAMPS 1.4 digital input 4 on the servos connector // #define FIL_RUNOUT_PIN 4 // define X_MAX_PIN 2 for the filament runout sensor. #define FIL_RUNOUT_PIN 2
#define FILAMENT_RUNOUT_SENSOR #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #define FIL_RUNOUT_INVERTING true // set to true to invert the logic of the sensor. //#define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins. //#define FIL_RUNOUT_PULLDOWN // Use internal pulldown for filament runout pins. // Set one or more commands to run on filament runout. // - Always applies to SD-card printing. // - Applies to host-based printing if ACTION_ON_FILAMENT_RUNOUT is not set. #define FILAMENT_RUNOUT_SCRIPT "M600" // With this option, if filament runs out during host-based printing, Marlin // will send "//action:" to the host and let the // host handle filament change. If left undefined the FILAMENT_RUNOUT_SCRIPT // will be used on filament runout for both host-based and SD-card printing. // // The host must be able to respond to the //action: command set here. // //#define ACTION_ON_FILAMENT_RUNOUT "pause: filament_runout" // After a runout is detected, continue printing this length of filament // before executing the runout script. Useful for a sensor at the end of // a feed tube. Requires 4 bytes SRAM per sensor, plus 4 bytes overhead. //#define FILAMENT_RUNOUT_DISTANCE_MM 25 #ifdef FILAMENT_RUNOUT_DISTANCE_MM // Enable this option to use an encoder disc that toggles the runout pin // as the filament moves. (Be sure to set FILAMENT_RUNOUT_DISTANCE_MM // large enough to avoid false positives.) //#define FILAMENT_MOTION_SENSOR #endif #endif
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 02, 2020 07:54AM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 02, 2020 09:30AM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 02, 2020 01:04PM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 02, 2020 02:52PM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 02, 2020 03:31PM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 02, 2020 09:29PM |
#define MOTHERBOARD BOARD_RAMPS_14_EFB which I later deturmined was a MKS Mother board and changed to #define MOTHERBOARD BOARD_MKS_GEN_13
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 03, 2020 11:23AM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 03, 2020 01:24PM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 03, 2020 02:27PM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 03, 2020 06:01PM |
#define MOSFET_D_PIN 7
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 04, 2020 04:40AM |
Re: geeetech i3 pro c marlin 1.1.8 "Filament out" configuration February 04, 2020 09:29AM |
