Configuration.h - Pegasus 8 LCD -(Basic)
Configuration.h - Pegasus 12 LCD
I have (3) Maker farm Pegasus Printers (2) Pegasus 8 and (1) Pegasus 12
All 3 were running 1.0.2 Firmware provided by the manufacturer, I was able to run a utility that allowed me to transfer the settings to more a recent version of the Marlin firmware.
For the most part this has made great improvements to all 3 units.
But the problem I have run into is that the all (3) units randomly stop with an error when running a "Auto Home" command with "
Homing failed, printer halted, please reset" this happens when initiated either manually or from the gcode prior to a print. As you can imagine this very annoying.
Most of the post I have found are hardware / wiring related. how ever I have made some hardware changes since i purchased them, I change the Z rods from M5 to T8, but this was long before I upgraded the firmware and I never experienced this error under the 1.0.2 firmware. I have attached the current firmware loaded on all (3) units. Perhaps their is some new vaibles in the newer config.h that I need to change to address the problem, Can anybody review the files and tell me what I need to change?
Thanks
