Need help with Z axis offset issue after auto leveling. Marlin V2 June 08, 2020 06:05PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 09:09AM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 05:26PM |
ruggb
when u start print, the first thing that happens is a G28, home all. 10mm sounds like an after homing backoff. When it starts printing, the first thing it does is a G0 Z0.
If you do a bed level and it works, then I would GUESS that your bed position is not stored and is reset each time you start a print. U need to do a bed level then do M500 to store that setting.
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 05:40PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 05:44PM |
ruggb
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 05:48PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 06:00PM |
ruggb
post your configs
what is set to 10mm
it would be good if you flagged the lines that you changed in your configs.
It makes it easier for you to upgrade and someone to scrutinize it.
I use //**
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 06:57PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 07:00PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 07:02PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 07:12PM |
Re: Need help with Z axis offset issue after auto leveling. Marlin V2 June 09, 2020 10:47PM |
