Modify Marlin 1.1.x for endless loop
July 16, 2020 04:05AM
I want to modify marlin 1.1.x firmware in order to make it run the gcode inside the sd card forever (until e-stop triggered)
Any ideas are welcome.
Regards,
Nuri
Re: Modify Marlin 1.1.x for endless loop
July 16, 2020 08:55AM
I don't know if this works but try putting the following at the end of your gcode file
M400 ; make sure all moves have finished so nothing is queued
M23 filename.gco   ; same gcode file these lines are in.
M24
Edited 1 time(s). Last edit at 07/16/2020 08:56AM by Dust.
July 16, 2020 01:10PM
We are very close
M23 loads the file but M24 did not start it
In the LCD it requieres resume print.
How can we solve it. Firmware mod is also possible for me
Regards
Nuri
July 16, 2020 06:13PM
Copy-pasting the GCODE into the file for about a thousand times isn't a solution I guess?
http://www.marinusdebeer.nl/
July 17, 2020 02:41AM
No smiling smiley
Can I add a M command that can rewind the program in the SD card and run it?
functions I may use
card.startFileprint();
card.openAndPrintFile(card.filename);
Any idea about how to implement this?
July 17, 2020 12:28PM
I know I'm off base by mentioning this but Teacup has a Canned Cycle built into it where G-code commands will be executed over and over until the reset button is pushed or the power is killed. It's used for exhibitions
VDX
July 17, 2020 02:17PM
... I've modified Pronterface to check for an "automode" flag and, if found, restart the load+run session anew ... but this was for running from the PC, not the SD card ...
Viktor
July 18, 2020 01:22AM
I have find the solution with @Dust's idea
First I upgraded my firmware to Marlin 1.1.9
I added at the end of my code file (filename.gco)
M32 filename.gco
Thank you everybody specially Dust
Regards
Nuri
July 18, 2020 03:59AM
nerginer
M32 filename.gco
Regards
Nuri
Ah! M32..
[marlinfw.org]
Easy to find indeed.
"The M32 command exists to allow G-code to load other G-code files and run them as sub-programs. This can be useful to change the start / end gcode for a batch of files without having to edit them all."
And very useful in certain situations... Hmmm. Never knew this. It might come in handy with the pen plotter I'm building.
Edited 1 time(s). Last edit at 07/18/2020 04:00AM by Ohmarinus.
