Absolut zero height without Z end switch
August 12, 2020 07:03AM
Hi Everyone,
I am relative new to 3d printing and have some (actually a lot of) questions. But this time I would like to ask help regarding absolute zero height. Let me explain a bit:
I long term I would like to use bltouch with ABL. I will have more question regarding this later but at the moment I wanted to do the initial bed leveling manually using the "paper method". After doing some G28 and G29 according to the result I had to lift the bed a bit. But probably my springs under the bed loose now so I at the maximum height. I thought I will lower the whole bed for example approximately 2 mm and move also the absolute 0 height on my printer. But I cannot find any way to move the 0 height down. I'm using SKR 1.4 turbo with bltouch attached to the probe connector not in the z min connector. From this point the Z end switch does nothing. I assume there is an absolute zero height set somewhere as the bltouch can only measure relative height to the bed. Where can I set the whole nozzel's zero level? (I'm only able to find the Probe's Z offset which is do nothing in regarding this.)
Thank you in advance!
Edited 1 time(s). Last edit at 08/12/2020 07:19AM by newbie69.
Re: Absolut zero height without Z end switch
August 12, 2020 11:27PM
I'm a little new also but have cnc experience. Can you explane how the z axis does the homing? Is there an endswitch and is it on top or bottom?
August 13, 2020 04:21AM
I'm using the probe for Z homing. No Z switch in the game...
August 13, 2020 04:42AM
You might be able to set a Z-max with an endstop at max and calculate maximum travel from there?
http://www.marinusdebeer.nl/
August 13, 2020 02:30PM
with the bltouch connected to the Z min input, you should be able to adjust the Z zero with the probe Z offset (negative value)
If you set this in the configuration.h then you need to update the eeprom value by sending
M502
M500
to the printer
August 13, 2020 04:45PM
My bltouch is connected to the probe port not into the z min. However I think I finally found the solution. If anyone is interested:
G28: move the probe to the center of the bed
M211 S0: enable to move Z into negative
- adjust the Z height using the display menu
M851 Z0: set the new Z zero point
M500: store everything in EEPROM
I tried too much thing at a single night. I think this was the correct which solved my problem. smiling smiley
Thanks to all of you who took the time to think on my problem!
