Marlin 2.0.7
New Features
- MarkForged kinematics (#19235)
New Machines and Boards
Board / HAL
- Emergency Parser for STM32F1 (#19279)
- LPC176x: Finish DMA transfer, use HW SPI class (#19191)
- Update HAL/STM32 platform to 8.0 (#18496)
- Ultratronics Pro SPI pins (#19444)
- Replace Serial with Serial1 in pins files (#19459)
- Raise STM32F1 UART IRQ Priority, add error handling (#19301)
- Adjust GTR PeripheralPins to avoid timer conflicts (#19183)
- Allow SWD debug on Robin Nano (#19345)
- Define UART pins for LPC debug based on
LPC_PINCFG_UART
(#19475)
- MKS Robin Mini uses
ONBOARD_SPI_DEVICE
(#19460)
LCD / Controller
- Working
LCD_USE_DMA_FSMC
(#19522)
- Update Italian language (#19365)
- Update German, fix Mix component index (#19206)
- MarlinUI for SPI/I2C TFT-GLCD character-based display bridge (#19375)
- Fix Touch UI long filenames, etc. (#19262, #19349)
- TFT: No timeout on Move Screen (#19426)
- Smoothieboard GLCD w/ SD support (#19241)
SHOW_REMAINING_TIME
for HD44780 character LCD (#19416)
- New Touch UI buttons (#19465)
- Fix missing spaces in info menu (#19404)
- Improve LVGL UI (#19442)
- Add warning to ExtUI Bed Mesh Screen. (#19397)
- Allow ColorUI color customization (#19484)
- Move screen for Color UI (#19386)
- Fix Longer3D TFT defines, disable DMA (#19251)
- Change “FR” on LCD to “>>” (#18830)
- Various updates for Ender 3 V2 controller:
- No “Bed Leveling” item on Ender 3 V2 for manual probing
- Highlight Creality DWIN menu icons (#19368)
- Revert LCD language to English on next boot
- Add more DWIN commands, docs (#19395)
- Use F() for Ender 3 V2 DWIN strings
- Other Ender 3 V2 (DWIN) issues (#19441, #19268)
Other Peripherals
Host and Protocol
- Allow
M524
between M23
and M24
- Escape the
M33
string arg (#19515)
- Add Host Action: Start (#19398)
M872
: Wait for Probe Temperature (#19344)
Issues Patched
- Fix Power-Loss Recovery for Ender 3 V2
- Read from backup TMC StealthChop state (#19364)
- Fix lost brightness during EEPROM load (#19485)
- Fix "too cold" in M600 (#19332)
- Fix Allen Key Probe pin test (#19520)
- Fix and improve STM32F1 serial (#19464)
- Fix Anycubic I3 Mega (S) original screen % display (#19210)
- Fix Anycubic LCDs / Trigorilla 1.4 pins (#19220)
- Fix case light brightness save/load (#19436)
- Fix compile for Taz Pro (#19424)
- Fix compile with Danish, Basque (#19325)
- Fix CoreXY compile with backlash calibration (#19422)
- Fix Creality V4 SD Detect
- Fix diveToFile with open Dir object (#19539)
- Fix EXP2 pin define for MKS SGEN_L (#19369)
- Fix extra string substitution bug (#19351)
- Fix M166 Gradient Mix for DELTA (#19285)
- Fix MBL "Click to continue" on Color UI touchscreen (#19514)
- Fix missing BOARD_K8800 (#19331)
- Fix MKS Robin undefined pins error (#19507)
- Fix MKS UI SPI flash typo (#19410)
- Fix Print Stats appearance (#19348)
- Fix SKR 1.4 thermistor pin comments (#19510)
- Fix STM32F1 SPI device init, MKS_LCD12864 (#19271)
- Fix UBL 'G29 I' for large meshes (#19231)
- Fix up K8800 pins (#19476)
- Fail SD mount without SPI re-init (#19226)
- No 'ls' if media isn't mounted
Optimized / Improved
- MMU2 S Mode spins the BMG gears during
C0
(#19429)
- Only show "SD Init Fail" with detectable media (#19236)
- Only set up SPI pins as needed (#19372)
- Misc. Power-Loss Recovery improvements (#19540)
- Improve temperature runaway, idle timeout (#19339)
- Make
M600
heat up the nozzle. Reset runout on fail. (#19298)
Configuration
- Warning if
SDCARD_READONLY
should be disabled
- Temp sensor for Kis3d Silicone heater + precision cast plate (#19528)
- Sanity check old serial names
- Sanity-check
BABYSTEP_DISPLAY_TOTAL
with ColorUI (#19284)
- Permit touch params override w/ Robin nano (#19196)
- Optional Host Start menu item (#19443)
- Optional menu item for Assisted Tramming (#19447)
- More configurable E3 V2 DWIN (#19384)
- Catch TMC address conflicts early (#19458)
- Clarify disabling StallGuard for axes (#19263)
- Demo and test multiple PID defaults (#19413)
- Cleanup of to configuration comments and formatting
- Expose
JOYSTICK_DEBUG
to general users (#19394)
Build and Upload
- Fix AnyCubic LCD dependencies
- Warn in
platformio.ini
about RCT6 512K (#19312)
- Include
pins.h
in dependency check (#19468)
For Developers
- Add extra
CardReader
debugging
- Add
CardReader::fileExists
(also updates the long name)
- Tweaks to git helper scripts
- New names for LCD conditionals (#19533)
Known Issues
- The
M85
timeout might crash M600
- Possible layer shift (stepper DIR signal bug) on IDEX machines.
