Start fan after reaching temperature December 22, 2020 11:20AM |
#ifndef MOTHERBOARD #define MOTHERBOARD 33 #endif
Re: Start fan after reaching temperature December 22, 2020 07:48PM |
Re: Start fan after reaching temperature December 22, 2020 09:58PM |
Re: Start fan after reaching temperature December 23, 2020 01:06AM |
Admin Registered: 13 years ago Posts: 7,003 |
Re: Start fan after reaching temperature December 23, 2020 03:47PM |
Re: Start fan after reaching temperature December 23, 2020 05:33PM |
Re: Start fan after reaching temperature December 23, 2020 06:11PM |
Re: Start fan after reaching temperature December 23, 2020 07:40PM |
Re: Start fan after reaching temperature December 23, 2020 08:28PM |
Re: Start fan after reaching temperature December 23, 2020 09:09PM |
#define MOTHERBOARD BOARD_MKS_BASE_14 // This sets the firmware to use dual extruder or dual fans #define EXTRUDERS 1
#ifndef MOSFET_D_PIN #define RAMPS_D7_PIN 7 // changed from -1 to disable #define MOSFET_D_PIN RAMPS_D7_PIN #endif #ifndef RAMPS_D8_PIN #define RAMPS_D8_PIN 8 #endif #ifndef RAMPS_D9_PIN #define RAMPS_D9_PIN 9 #endif #ifndef RAMPS_D10_PIN #define RAMPS_D10_PIN 10 #endif #define HEATER_0_PIN RAMPS_D10_PIN #if ENABLED(IS_RAMPS_EFB ) // Hotend, Fan, Bed #define HEATER_BED_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EEF ) // Hotend, Hotend, Fan #define HEATER_1_PIN RAMPS_D9_PIN #elif ENABLED(IS_RAMPS_EEB ) // Hotend, Hotend, Bed #define HEATER_1_PIN RAMPS_D9_PIN #define HEATER_BED_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EFF ) // Hotend, Fan, Fan #define FAN1_PIN RAMPS_D8_PIN #elif DISABLED(IS_RAMPS_SF ) // Not Spindle, Fan (i.e., "EFBF" or "EFBE") #define HEATER_BED_PIN RAMPS_D8_PIN #if HOTENDS == 1 #define FAN1_PIN MOSFET_D_PIN #else #define HEATER_1_PIN MOSFET_D_PIN #endif #endif #ifndef FAN_PIN #if EITHER(IS_RAMPS_EFB, IS_RAMPS_EFF ) // Hotend, Fan, Bed or Hotend, Fan, Fan #define FAN_PIN RAMPS_D9_PIN #elif EITHER(IS_RAMPS_EEF, IS_RAMPS_SF ) // Hotend, Hotend, Fan or Spindle, Fan #define FAN_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EEB ) // Hotend, Hotend, Bed #define FAN_PIN 4 // IO pin. Buffer needed #else // Non-specific are "EFB" (i.e., "EFBF" or "EFBE") #define FAN_PIN RAMPS_D9_PIN #endif #endif
