Hello, pretty new user to this forum and hope i'm following all the rules :-)
I have a creality cr-10s pro v2. Everything was working as expected up to the point whern i decided i needed a e3d titan earo head.
Unfortunately creality only release the .hex file for this machine or a marlin source for the cr-10s pro - without bltouch.
It took a while to get a working marlin setup to the point where i am now. First i tried to get marlin2.0 working, but the screen was always stuck on booting.
I now have a marlin 1.1.6. installed. The bltouch is self testing when booting and reacts to gcode. But when i tried to home the z-axis keeps moving after i trigger the bltouch by hand. When i use a different .hex file the homing procedure works fine, so i think the sensor itself is fine. Problem with using that hex file is that i can't adjust the homing or probe offsets enough.
I have attached my config files. Is therre anyone here that had any suggestions to get the homing working?
Thanks, jochem.
