Feed rate not respected when moving very slow September 02, 2021 10:19AM |
M205 B0 E0 S0 T0 X0; Setup Jerk, jerk is the minimum speed that the motors move M302 S0 ; print with cold hotend -- This allows cold extrusion, but we aren't doing any, maybe when we use the stepper motor of the extruder too M121 ; don't use endstops G91 ; relative positioning ; Start move code M92 X-20927 Y-20927 Z20927; Very high steps/mm because of my custom application G1 X0.05 F0.2; takes 9 sec instead of 15The problem is that the stepper motor stops turning too soon, after 9 seconds instead of after 15. I am not sure if the full distance is moved, or if just terminates early.
; Start move code M92 X-20927 Y-20927 Z20927; Should equate to steps per ml G1 X0.05 F0.35; 8.5 secWorks properly.
