Re: btt skr mini e3 v3 + ender 3v2 May 02, 2022 11:28AM |
Admin Registered: 13 years ago Posts: 7,007 |
/** * ------ ------ * (ENT) |10 9 | (BEEP) |10 9 | * white-----(RX) | 8 7 | white---(RX) | 8 7 | (TX)---black * black-----(TX) 6 5 | (ENT) 6 5 | (BEEP) * (B ) | 4 3 | (A) (B ) | 4 3 | (A) * GND | 2 1 | (VCC) GND | 2 1 | VCC * ------ ------ * EXP1 DWIN * * All pins are labeled as printed on DWIN PCB. Connect TX-TX, A-A and so on. */
Re: btt skr mini e3 v3 + ender 3v2 May 02, 2022 12:14PM |
Re: btt skr mini e3 v3 + ender 3v2 May 06, 2022 10:25PM |
Re: btt skr mini e3 v3 + ender 3v2 May 08, 2022 05:29PM |
Re: btt skr mini e3 v3 + ender 3v2 May 09, 2022 10:10AM |
Re: btt skr mini e3 v3 + ender 3v2 May 09, 2022 01:21PM |
Re: btt skr mini e3 v3 + ender 3v2 May 09, 2022 10:25PM |
[email protected]
Here's a video that's very clear about how to plug in the wires for your setup:
You would need to go back to using the Z probe as the Z end stop.
Re: btt skr mini e3 v3 + ender 3v2 May 09, 2022 11:18PM |
Re: btt skr mini e3 v3 + ender 3v2 May 11, 2022 02:44PM |
[email protected]
The only thing I can think of is to use the M43 S servo probe test to verify that the probe's signal is getting back to the MCU.
Re: btt skr mini e3 v3 + ender 3v2 May 11, 2022 05:11PM |
Re: btt skr mini e3 v3 + ender 3v2 May 18, 2022 06:24PM |
Re: btt skr mini e3 v3 + ender 3v2 May 19, 2022 02:42AM |
Re: btt skr mini e3 v3 + ender 3v2 May 19, 2022 02:57AM |
Re: btt skr mini e3 v3 + ender 3v2 May 19, 2022 06:00PM |
Yes, it is already connected all 5 wires to the Z-probe connector on the board. The clip above is using your firmware you have shared. That is the behavior it is displaying.Quote
hddvrn
Please connect the CR touch cable to the standard connector of the board. The printer does not see the sensor response.
Re: btt skr mini e3 v3 + ender 3v2 July 09, 2022 09:03AM |
Re: btt skr mini e3 v3 + ender 3v2 July 09, 2022 10:05AM |
Re: btt skr mini e3 v3 + ender 3v2 July 09, 2022 12:27PM |
Re: btt skr mini e3 v3 + ender 3v2 July 09, 2022 02:22PM |
[email protected]
I've had a lot of "fun" trying to get fans to run at less than 100%. Most ran at 100% or nothing. A few run at about 75% and higher. For my nozzle fan I ended up buying a PWM fan which meant I had to supply power, ground and a PWM signal. On one of my printers I just found a fan that moved more than enough air and then blocked the inlet.
Re: btt skr mini e3 v3 + ender 3v2 July 09, 2022 02:43PM |
